XBee Pro API
I've been working on a project where I need to use non-mesh XBee's in API mode and 64-bit addressing. After a couple days, it is starting to work. I was only going to write in the functionality I need, but if there is anyone with interest in this let me know what you need/want.
JMH
I have a project where I will have 4 xbee's in a chain. I will need to have them pass data so that I can send a query or command to the xbee at the end of the chain. So, I need to figure out how to pass data from one unit to the other. Any help in this would be much appreciated.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
So, is MESH a firmware or hardware thing? I have xbee pro 60mW units. I took a quick look in the docs (I'm at work) but didn't see anything about mesh.
Thanks!
@Jonathan: If you have a 60 mW output I'll assume you're reffering to the 802.15.4 modules (actually 63 mW):
www.digi.com/products/wireless/point-multipoint/xbee-series1-modulespecs.jsp
If you have all Maxstream devices, you can flash these devices with the Maxtstream proprietary DigiMesh protocol to get mesh networking (it is not ZigBee compatible, but faster).
They also sell a Zigbee ZB product, formerly known as Zigbee 2.5 but now with a firmware upgrade and brand new marketing, it IS different hardware than the module above so not firmware compatible, it is found here:
www.digi.com/products/wireless/zigbee-mesh/xbee-zb-modulespecs.jsp
but I would stay away from this unless you have ZigBee specific devices from other manufacturers that you're trying to talk to - for why, see below
Since I haven't seen it posted anywhere else I'll provide some hard numbers I've gathered regarding range and actual realized throughput for the different modules. *the numbers assume a standard dipole antenna and a relatively quiet chunk of spectral space*
2.4 GHz
Zigbee module realized throughput: 25 kbps - ouch that's slow, there's lot of overhead in this protocol...
802.15.4 module realized throughput: 115 kbps
I'm not sure what the numbers are for DigiMesh since I don't need mesh in my application, but I understand it is at least 3x their Zigbee module.
range with los: 1 mile - if you add a 6 db gain into either the Tx/Rx of the system you can double this range
range with non los: 300 ft - if you add a 12 db gain into either the Tx/Rx of the system you can double this range
Although WiFi and 802.14.5 have collision avoidance and can coexist, it is good to minimize problems and optimize channel selection. I have a spectral analysis of a WiFi network operating across different channels with the Maxstream modules to image the overlap. Wi-Fi (802.11x)has 3 non overlapping channels in the US - 1, 6, and 11. So, these are the most commonly selected channels for Wi-Fi with channel 6 often the default. Assuming this, you can select channels 0x0F or 0x14 for the Maxstream to minimize probability of Wi-Fi interference. But ISM 2.4 is crowded with phones, microwaves and all sorts of stuff, so 900 is likely better for you. In general, when working with the Maxstream devices, I would stay away from 2.4GHz for most applications, since their 900 MHz modules will have better throughput and range than their 2.4 counterparts.
900 MHz
www.digi.com/products/wireless/point-multipoint/xbee-pro-900.jsp
module realized throughput: 156 kbps
range with los: 3 mile
range with non los: 450 ft
The 900 MHz can be loaded with the DigiMesh firmware too if you need it, again you'd have to test what the overhead looks like.
Again, what are you going to include in the API? Just post the damn thing and let us experienced people start critiquing and offering suggestions.
Are you ashamed to post your code? Don't be - perfection doesn't exist.
JMH
