Did I just smoke my Propeller Development Board?
Okay, so I'm dumb. I started working with the Prop Development Board for the first time and I figured I could use a generic wall wart I had laying around, which said it had the right voltage and amps. Long story short, I found out that, although it plugs into the Prop Dev Board ever so nicely, it has a polarity that is reversed from that required by the Prop Dev Board. Stupid me, I didn't even know such a polarity reversal was possible. After all, electronics people are smart, and surely they wouldn't use the same connector for different polarities... right?
Question is: did I ruin my Prop Development Board? or does it have some sort of built-in anti-idiot robustability?
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Post Edited (mctrivia) : 3/2/2009 12:38:19 AM GMT
Can't hurt to see if it still works, right?
Can't hurt but it means I have to drive out and buy a new wall wart.... when the other option is to abandon the Prop Development Board and go for a different package for the Prop. I just wanted to know what the chances are that I sizzled it.
Good idea. Luckily I found a wart that works and the PDB seems to have survived my ignorance. I guess it's best to presume NOTHING when making connections with found components.
Thanks everyone,
Mark
· -- Carl, nn5i@arrl.net
I hope you don't have to be dumb to hook things up backward, for I did it yesterday to an LCD display that plugs into a 2x5 Berg header on my Prop design.· It was like that for about a minute or more while I tried to figure out why it was just flashing instead of showing the expected display.· At length I said "oh, my goodness" or perhaps something stronger, turned off the power, hooked it up right, and -- mirabile dictu·-- it still worked.
Thanks, Carl, that sounds like very good advice.
If you really damaged the board we would replace or repair it for you, often for free. After seeing how you sluethed your way through this with the help from the forum we have nothing but support for you should you need to call upon us for repair or replacement.
--Steve
I wish you goog luck
Hi Ken,
that's a mighty generous offer you have there, but I certainly am not blaming the design of the Propeller Development Board for my stupid mistake. I should know better than to blindly connect things together like I did. In any case, your design seems to have survived my careless attack.
thanks!
Mark
