Different programming for bs2 and bs2p
I have a system that runs with two bs2's and I tried to replace them with bs2p's.· The software seemed to write OK, but doesn't execute.· I am using PBasic 2.0.· I thought that the bs2p also used PBasic 2.0.· Am I wrong?· Are there some differences I am not aware of?· Also, I thought the pinouts are the same as well.· Any help would be appreciated!
On the code side, what are you trying to do? If you can paste your code that would help.
Dave
The problem you are seeing though is more likely due to the fact that the BS2p operates at a different speed to the BS2 so any time sensitive instructions in your code will not work as they did before eg: SERIN/SEROUT . The Pbasic help files document the differences.
Jeff T.
If you start out your code with these compiler directives:
#SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T9600 CON 84 T19K2 CON 32 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T9600 CON 240 T19K2 CON 110 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T9600 CON 396 T19K2 CON 188 T38K4 CON 84 #ENDSELECT Inverted CON $4000 Open CON $8000 Baud CON T9600 + Inverted ‘ NOTE: Select the Settings you need here SerRecv PIN 0 ' Select your Serial Input pin here SerXmit PIN 1 ' Select your Serial Output pin herethen use SERIN SerRecv, Baud, [noparse][[/noparse]data2get...
etc.
This will automatically change based on your {Stamp} directive when you compile the program
Smile ... It increases your face value!
