Whats a good next step chip after the BS2? & What is Scratch Pad RAM? — Parallax Forums
SteveWoodroughSteveWoodrough Posts: 190
edited 2009-03-01 03:04 in BASIC Stamp
While I cannot say that I have mastered the my BS2 chip I am writing applications that could use more memory and maybe more variable space.·I'm considering just going to the BS2e but I will consider going larger if there is a true quantum leap in performance with the·"bigger" chips.
What is Scratch Pad RAM and how is it used?
Thanks for your input!
Steve·
  • ZootZoot Posts: 2,227
    edited 2009-02-27 02:31
    Scratch Pad RAM is basically like regular variables --EXCEPT that you can't perform operations on them directly; you have to "load" them into regular (temporary) variables, do your operations on them, then "save" them again if you need to.
    Here is a simple example, where the motor speeds are stored in Scratch Pad RAM. The idea is that you don't take up "normal" variable space for anything but absolute essentials, leaving most of your space as "work" space....
    IRdet PIN 1 ' an IR detector
    ML PIN 2 ' servo
    MR PIN 3 ' servo
    buffer0 VAR Byte ' temp. work byte
    buffer   VAR buffer0 ' alias to use as 3 element array
    buffer1 VAR Byte ' ditto
    buffer2 VAR Byte ' ditto -- note that these 3 variables can also be an array: buffer(0), buffer(1), buffer(2)
    MotorLeft CON $10 ' the "address" or index of the Scratch Pad register for this motor speed
    MotorRight CON $11 ' ditto
    MotorRamp CON $12 ' ramp speed
    Main:
       ' here's my "behavior" code....
       IF IRdet = 0 THEN
          GET MotorLeft, buffer0  ' load work vars with last known motor values
          GET MotorRight, buffer1 ' so we can do stuff to 'em
          GET MotorRamp, buffer2 ' ditto
          buffer0 = buffer0 + buffer2 ' add motor ramp to left motor
          buffer1 = buffer1 - buffer2 ' subtract motor ramp from right motor (we're turning)
          PUT MotorLeft, buffer0
          PUT MotorRight, buffer1 ' save the values
       ENDIF
       ' then who knows, lots more code here, reams and reams of it....
       ' then at the end, after all the main code has "massaged" the motor speed values, we dump them to output....
       PULSOUT ML, buffer0
       PULSOUT MR, buffer1
    There's lots of ways to load/save/parse SPRAM -- you can save/load arrays, or Words, or byte streams from serial/i2c commands, etc. The only thing you can't really do directly is bit or nibble operations; for those you need to load the SPRAM register(s) into regular variables, then use aliases or nib/bit assignements for the normal variables, i.e.
    GET 10, ioByte ' load address 10 into ioByte
    IF ioByte.BIT4 = 1 THEN
        ' do something
    ENDIF
    edited 2009-02-27 02:37
    1) Keep in mind that the additional program memory on the other Stamp models comes in "slots" of 2K. Essentially, you can have several mostly separate programs stored in a Stamp, each 2K. You can jump around from program to program, but it's not a "call". You can't really return to the same place in the original slot after transferring to another slot. There's a Nuts and Volts Column on the subject that goes into details.
    2) Scratchpad RAM is just a section of memory available on most Stamp models other than the BS2. Its contents go away when the power goes off and you access it using the GET and PUT statements (see the manual for details). The input statements (like SERIN) can read a string of bytes directly into scratchpad RAM, but that's pretty much all the built-in support it has. It's handy for some programs that have to process long strings of characters like from a GPS receiver.
    3) The biggest increase in capability is with the BS2p/pe/px models because of the additional statements. The BS2px adds some additional flexibility in how you can configure I/O pins as well as speed. I don't know whether I'd consider that a "quantum leap". It's certainly a substantial incremental improvement.
    4) My bias "after the BS2" is to consider the Propeller. It is definitely a "quantum leap" in terms of capability and raw speed. It's quite different from the Stamps and not as easy to use, but there's quite a bit now of tutorials on its use and many of the functions done by Stamp statements can be done using subroutine calls with the "BS2 Compatibility Library".
  • SteveWoodroughSteveWoodrough Posts: 190
    edited 2009-02-27 03:51
    Thanks for the input. I was hoping to hear from your guys. The propeller is is probably the way to go, I just do not look forward to the learing curve. Once my current project is ready for YouTube I'll ask for a critique of my programing skills.
    Mike, you mentioned something particularly interesting: I take from your first comment that I will not really get 8 times more programming space in the sense that the EEPROM memory map will not get 8 times bigger.
    With that in mind: I'm a big fan of subroutines. I have no formal training writting code so essentially what I do is write a bunch of subroutines. Below is the main code that takes input from a TV remote, and directs the bot in several modes. Sub routines lead to sub routines containing LOOPS, CASE, RCTIME etc. The program is small (see below) its the subroutines that take up all the room.
    Question: Will that type of program structure work if the main program is in 1 slot and the subroutines are distributed in the other slots?
    If anyone has a link to the Nuts and Volts article Mike mentioned I would appreciate it.
    Thanks, Steve
    [noparse][[/noparse] Main Routine ]
    Main:
    DO
    speed = 0
    GOSUB GetModeData
    IF mode = 1 THEN
    GOSUB GetSpeedData
    GOSUB Roaming
    ELSEIF mode = 2 THEN
    GOSUB RemoteControl
    ELSEIF mode = 3 THEN
    GOSUB DirectionDistance
    ELSE
    SEROUT LCD, 84, [noparse][[/noparse]148, "Enter Valid Mode"]
    PAUSE 1000
    ENDIF
    LOOP
    END
    edited 2009-02-27 04:03
    If "mode" is one of your essential (global) variables, then you can put each sub, or each group of subs in a slot. Then the "mode" variable decides what happens as you run from slot to slot. With careful organization, your program space does increase 8 fold. You just have to approach things a little differently. E.G.,
    ' slot 0 program
    mode VAR Byte
    IF mode = 0 THEN GOSUB x
    IF mode = 1 THEN GOSUB y
    RUN 1 ' now run all the code in slot 1
    x:
     'hugely long sub
      RETURN
    y:
     'ditto
      RETURN
    ' slot 1 program
    mode VAR Byte
    IF mode = 2 THEN GOSUB z
    IF mode = 3 THEN GOSUB a
    RUN 2 ' now run all the code in slot 2
    z:
     'hugely long sub
      RETURN
    a:
     'ditto
      RETURN
    ' slot 2 program
    mode VAR Byte
    IF mode = 4 THEN GOSUB b
    IF mode = 5 THEN GOSUB c
    RUN 3 ' run the output slot
    b:
     'hugely long sub
      RETURN
    c:
     'ditto
      RETURN
    ' slot 3 program
    mode VAR Byte
    GOSUB LCD_OUT
    RUN 0 ' back to beginning
    LCD_OUT
     ' hugely complex and radically cool LCD display output code
      RETURN
    P.S. -- Mike is probably right about the Prop smile.gif and it's certainly inexpensive compared to a Stamp, with more pins, but there are lots of ways to leverage SPRAM and slots beyond string management. See some of Tracy Allen's app notes -- emesystems.com/BS2SX.htm#variables
    Post Edited (Zoot) : 2/27/2009 4:08:42 AM GMT
    edited 2009-02-27 04:34
    So I'm OK as long as each mode only accesses a set of subroutines that can fit in a slot.· However, if the subroutines are not all in the same slot or if a subroutine reference a subroutine in another·slot,I'm hosed?· I think I'm hosed.·
    Attached is a draft of the code to date.· It's not fully commented and still only half baked but I have a hard time seeing a good way to separate out· the subroutines into discrete slots.· Each mode controls the bot in a different way.· One using the IR sensors, 1 using the TV remote, one using the compass module, etc.· Each mode relies on commonly used subs.· There is some junk in here I can delete but I had more functions and modes planned.· Perhaps there are more efficient ways to write the code.
    THANKS!! Steve
    edited 2009-02-27 04:50
    The link for multi-slot programming is here (www.parallax.com/Resources/NutsVoltsColumns/NutsVoltsVolume3/tabid/445/Default.aspx), column # 87.
  • SRLMSRLM Posts: 5,045
    edited 2009-02-27 06:05
    You can take a look at the code that I've posted here. It uses a BS2, and breaks things up into logical slots. It's a little amateurish, but it worked well. What worked best for me was to break things up into big blocks: initialization, datalogger interaction, roving program (movement), stationary program, etc. The slot situation isn't the best solution for breaking up big programs, but it works okay. I used lots of conditional GOTO type statements, with flags set in the SCRAM so that I could have inter slot "sub routines".
  • UghaUgha Posts: 543
    edited 2009-02-27 15:43
    While a more powerful BS2 or a Prop are absolutely valid options...
    Also consider switching to the SX. I've found the move from a plain BS2 to an SX to be fairly easy using SX/B.
    Note that almost all the forum guys will recommend you learn assembly, but for most applications that a newbie/moderate will use a microprocessor for, SX/B works fine.
    After learning SX/B you'll find a whole new world of posibilities opening up to you.
    edited 2009-02-27 18:26
    Steve,
    If you do continue with the BASIC Stamp, go with one in the p/pe/px series. They have more ScratchPad RAM than the BS2e or 'sx, and they also have the STORE command that lets your program easily access data that is stored in slots other than the currently running one. Those resources are invaluable for developing multislot programs. They also have additional i/o commands such as for I2C and OneWire.
    I use the following scheme to call and return to routines that lie within other slots. The important thing is to have a systematic mechanism in place for doing this. It is possible to do it ad-hoc, but being systematic pays off as the plot thickens.
    # a) routine in one slot needs to call a routine that resides in another slot. It PUTs a return index into a location "back" set aside in scratchpad, and sets a special variable to point to the target routine in the other slot. These two pointers both have the same format,
    NIB1 is the slot number from 0 to 7 of either the origin or target slot, and
    NIB0 is an index from 0 to 15 that points to a specific routine in the origin or target slot.
    In the origin slot, the program issues a RUN command to the slot stored in NIB1: RUN bss.NIB1
    # b,c) execution commences in the target slot. At the top of that slot is a BRANCH instruction looks up the index in NIB0, which takes program execution to a the specified target routine: BRANCH bss.NIB0,[noparse][[/noparse]myb0, myb1, myb2, myb3] ' up too my15 if needed
    # d,e) the target routine executes, then GETs the return index and bank number from the location "back", and RUNs back to the origin slot: GET back,bss : RUN bss.NIB1
    # f,g) execution recommences in the origin slot, where another BRANCH resolves return location: BRANCH bss.NIB0,[noparse][[/noparse]mya0, mya1, mya2]. The overall mechanism is completely symmetric for both targets and return points.
    # h) the program resumes execution where it left off, or wherever the return mechanism needs it to be.
    Caveats and tips:
    -- Can't do from within a subroutine, has to be from top level (RUN trashes the return stack)
    -- Can't do from within FOR-NEXT loop (RUN trashes FOR:NEXT pointer, use DO:LOOP instead)
    -- This uses a single level return stack for cross-slot. Deeper stack is possible, but requires more overhead and bug potential.
    -- Minimize the number of cross-slot calls. They are relatively slow. It is better to duplicate some low level code.
    -- You can GET location 127 in order to determine the current running slot, in order to make code portable from slot to slot.
    -- The index that goes into NIB0 can be named systematically in relation to the routine in the other slot.
    mya1x CON $01 ' mya1x is return point #1 in slot 0, to a label mya1:
    myb3x CON $42 ' myb2x is routine 2 in slot 4, to label myb3:
    Tracy Allen
    www.emesystems.com
    Post Edited (Tracy Allen) : 2/27/2009 6:36:23 PM GMT
    151 x 194 - 3K
    edited 2009-03-01 02:53
    Thank You all very much for your input. I'm probably still a few months out from truely maxing the BS2 memory, but I like to plan ahead. Ironically, I'm not too much a plan ahead guy when it comes to robot functionality. As I code, I get ideas and try to make the idea happen. I try not to add goofy non relevant functions. With the BS2 e/p/pe/px series I get a sense that using the slots I'd better have a good idea where I'm going before I start out. Having said that I guess the question is: Which is "easier" keeping track of data and pointers from slot to slot or just bite the bullet and start learning SPIN?
    A few parting questions regarding SPIN and using a Propeller:
    Can I put all my code in one place (slot) and focus on the project task?
    Do I have to learn Assembly?
    Can I still easily control servos?
    Send and receive signals to my Parallax Servo Controller?
    Accept IR data from a TV remote?
    Use IR sensors to detect objects?
    Easily read the PING sensor?
    Easily read the Compass module and accelerometer?
    What can I not do in SPIN that I can easily do in PBasic?
    Thank You
    The propeller doesn't have 'slots' like the basic stamp. It has cogs which are functionally very different.
    No, you don't need to learn assembly.
    One of the forum members has a saying "It's harder to do the easy stuff with the propeller, and easier to do the hard stuff". Yes, you can control servos, but it will take a bit more initial work.
    See last answer.
    See last answer.
    See last answer.
    The compass module has code provided in assembly, but you should be able to create a Spin routine. That's one of the things on my project list, anyway (along with the required arctan function).
    You can't work easily with bit or nibs.
    See this link: http://forums.parallax.com/showthread.php?p=765086
