debug prop hardware
Ok ill keep this short to start.. ive recently started making my own prop boards.. i jsut made a cool tiny one with smd parts.. does anyone know off hand the possible causes of a prop outputing like 1.5 - 2ish volts on all the io pins could be.. Fried prop?· Its a pretty simple board, similar to the schematic for a prop proto board.. The first one i soldered up worked fine.. Wierd thign is i was·even more carefully when soldering this one.. It seems to download and detect the prop fine from the propller tool. I can even write the program to ram(f10) or so it seems(not getting correct voltages out of the chip). But if i try write it to the eprom (f11) it gives me an error. ive checked the Smile out of the board all seems fine no solder bridges etc all resistors in check...getting·3.28v on vdd... ·anyway i thought id toss it out see if anyone had any insight.
I've learned that the next step after ohming out the board as well as you can on ground and power is to make sure all data paths do not have a short to either. Next, install the regulators and power up. Look at current, if it's high then turn off and start over. If current seems right, (very LOW) then put a pulldown resistor (1K ohm) somewhere on the output side of power path and check all of the power pads. I've used a resistor actually tied to the tip of the probe from the VOM and ground.
Jim-
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
I·just built from scratch another board. I did it incementally...
first thing i tired was just the prop by itself. no crystal no eprom etc just the vreg and checked it im geting 3.28 volts at the vdd and vss pins of the prop.... prop tool detects the propeller fine.. even downloads code into it it seems... however again even with this second board im getting like 1.5ish volts out of all the i/o pins.. i wrote a litlte test blinker which will slowly pulse a pin. it downloads if i dont try two write it to epromm but it doesnt seem·toggle the pin it just puts out a·constant 1.5ish out of all pins.. theres no shorts and current draw seems normal.. There has to be something im totally missing..· i built 3 boards.. first one pretty much works perfectly... these second two are doing the same thing.. they are all from the same batch of pcbs and same parts,·im about to cry [noparse]:)[/noparse]
so at this piont i have a very cleanly soldered very quick short solder times on each pin.· prop, eprom, vregulator, xtal and 10k resistor. i left caps out for now.
I dont know what to do next.[noparse]:([/noparse]
Post Edited (s2jesse) : 2/28/2009 4:21:44 AM GMT
Try placing a 1uF cap across the Prop voltage pins.
Need to make your prop design easier or secure? Get a PropMod $50CAN has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module.
