Many words
I'm a newbie using SX/B 2.0 and wish that a manual were available.
I am working on a project that requires operations on the data from several sensors. Each sensor requires maintaining 6 values. Since each value is in the range of 0-30000 I need 12 bytes of storage per sensor. How can I store the data words using one bank for each sensor? I can find many examples of aliasing a named byte to an array element but nothing similar for word variables.
aWord var byte(2)
is an implied word.
You can then access the both bytes of aWord as
aWord_LSB and aWord_MSB.
regards peter
INC aWord
bWord = aWord
cWord = aWord + bWord
instead of having to explicitly work with aWord_MSB and aWord_LSB? I realize that this is what the compiler actually does but hiding things makes the source code much easier to follow and less prone to error.
I mentioned the LSB and MSB parts as these are also generated for the
normal words.
regards peter
sensor0 VAR Byte(2) BANK
speed0 VAR Byte(2)
voltage0 VAR Byte(2)
revs0 VAR Byte(2)
thisCnt0 VAR Byte(2)
sensor1 VAR Byte(2) BANK
speed1 VAR Byte(2)
voltage1 VAR Byte(2)
revs1 VAR Byte(2)
thisCnt1 VAR Byte(2)
I could write:
ASM
BANK sensor1
ENDASM
revs0 = revs0 + thisCnt0
and revs0 would actually operate on revs1? It would be nice to have one set of code for all sensors and just change the bank number to work with individual sensors.
[noparse][[/noparse]Edit] I changed the PUT_WORD and GET_WORD routines so they can be used from any bank.
[noparse][[/noparse]Edit] Fixed error found by Peter Verkaik in PUT_WORD -- upgraded to 2.00.13+ features to force promotion of bytes to words. See Peter's version (below) for even more features.
Post Edited (JonnyMac) : 3/1/2009 6:38:51 PM GMT
sensordevice0 var byte (10) bank align
sensordevice1 var byte (10) bank align
sensordevice2 var byte (10) bank align
sensordevice3 var byte (10) bank align
sensor VAR word @sensordevice0(0)
speed VAR word @sensordevice0(2)
voltage VAR word @sensordevice0(4)
revs VAR word @sensordevice0(6)
thisCnt VAR word @sensordevice0(8)
I used align to ensure the absolute offset of fields to start of banks is
identical for all sensordevices, which they must.
bank @sensordevice0
revs = revs + thisCnt· 'this uses variables of sensordevice0
bank __DEFAULT
bank @sensordevice3
revs = revs + thisCnt· 'this uses variables of sensordevice3
bank __DEFAULT
I would create subroutines that operate on sensorfields
and pass the bank value as well
SUB mySensor· 'let first parameter be the bank
· fsr = __param1 'this accesses the correct bank
· revs = revs + thisCnt
· bank __DEFAULT· 'enable default bank upon return
ENDSUB
You call this sub like
mySensor @sensordevice3,....
Be careful when doing math on both sensorfields and other variables that are
in different banks. Those 'outside' variables need either be copied to __paramX
global ram or to temporary variables declared inside the sensordevice bank.
I usually use the latter as __paramX is of course used by SXB.
So I would add following sensorfields:
sensorTempW1 VAR word @sensordevice0(10)
sensorTempW2 VAR word @sensordevice0(12)
You can copy 'outside' variables via __paramX to sensorTempX
and then do the math.
If you need to switch between banks, declare a local byte to hold
the bank value.
· sbank var byte
· sbank = __param1
· __wparam34 = myOutsideVariable 'sxb retrieves an outside variable
· fsr = sbank· 'this accesses the correct bank
· sensorTempW1 = __wparam34 'save the variable locally
· revs = revs + sensorTempW1
ENDSUB
regards peter
BANK @sensor1
value1 = 2
instead of
PUT_WORD @sensor1,`,2
The sample Words2 gets several compiler warnings such as "Line 282, Warning 48, Pass 2: File register not in current bank". Can these be ignored? What should be changed to make it compile without warnings?
-- http://forums.parallax.com/attachment.php?attachmentid=0
Post Edited (JonnyMac) : 2/28/2009 10:09:21 PM GMT
Exactly: PUT_WORD and GET_WORD are for bank-to-bank transfers. When you're inside a sensor bank you can freely manipulate its contents. I don't know how to suppress that compiler warning and wouldn't want to as it could be a real problem in some cases (though not in this one).
fsr = @sensor1 instead of bank @sensor1.
(but note that·fsr =··destroys W).
regards peter
There is a problem in PUT_WORD
SUB PUT_WORD ASM MOV __PARAM5, FSR ' save current bank MOV W, __PARAM1 ' start of array CLC RL __PARAM2 ' index *= 2 ADD W, __PARAM2 MOV FSR, W ' FSR = array(index) MOV IND, __PARAM3 INC FSR ' FSR = array(index+1) SB __PARAMCNT.2 ' skip next if word CLR __PARAM4 ' else clear MSB if byte MOV IND, __PARAM4 MOV FSR, __PARAM5 ' restore bank ENDASM ENDSUBYou save fsr in __param5, but later on you test __paramcnt.
Since __paramcnt is aliased to __param5 this will not work.
Better to change PUT_WORD to always use word values (or extend bytevalues to wordvalues)
PUT_WORD·SUB·4, 4, byte, byte, word
__paramcnt is not used then.
regards peter
I added subs/funcs for named variables that use the variables address rather than·the array index.
Disadvantage of using an index is that if you ever change the order of fields
you must change indexes throughout your program. Using named variables
that should not be neccessary.
I also added subs/funcs for byte values (index and named variables).
Finally, I also added two macros for named variables that either call a
word function or byte function based on the variable names.
The idea is that if the type of the variable changes, you don't need
to change calls throughout your program as the macros take care of that.
regards peter
First - I love reading your code - you produce excellent solutions -
Couple of questions:
For the 'index word' variants you use:
··· MOV·· W, __PARAM1····' start of array
··· CLC
··· RL··· __PARAM2····' index *= 2
··· ADD·· W, __PARAM2
to compute the index; would there be a downside to using:
I -think- it saves a byte and a cycle ...
Secondly - the GetName/PutName variants are clearly rather larger - but obviously I understand the reason not to want to use hard-code numbers for the index vars ...
I wonder however, could you not equate the 'field labels' as index offset constants·and then use the regular index routines?
David
That code is my fault and as Assembly is still not my first choice I'm not always particularly efficient with it. I appreciate that you provide alternative approaches -- has been very educational.
I really would like to try to find a way to produce a code library for the SX - you and Peter and others produce dozens of examples of great code - but there is no 'easy use' repository of it all ...
Yes and so I did.
I have abandoned the index and named routines all together
so now I have only 4 byteindexed routines and 2 macros.
The byteindexed routines do not double the index so they
can be used even if an array supports wordfields and bytefields.
The 'problem' with fieldaddresses is that they are absolute and
not relative to the arraybegin. To support multiple instances
of identical objects (like sensor1 and sensor2 in·the demo)
not only the address of the instance but also the address of
the object definition must be given.
I have resolved that using two macros GET_VAR and PUT_VAR
that you call like this:
\GET_VAR resultName,objectName,objectField,objectInstance
\GET_VAR objectName,objectField,objectInstance
\GET_VAR resultName,varName
\GET_VAR varName
\PUT_VAR objectName,objectField,objectInstance,value
\PUT_VAR varName,value
\PUT_VAR varName
Check out the generated code in the list view.
The subroutines do not yet suppoert spanned banks on the sx18/20/28.
regards peter
· By putting the line "\LIST Q=48" (without the quotes) right after the DEVICE line with prevent the "File register not in current bank" warning.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
but I think I prefer your solution - because you are using macros and constant folding the extra subtract is not really costing you anything ...
David
Also added functions for reading ROM.
regards peter
compliant with spanned arrays. All fixed now.
Just replace the INC file with the one attached.
regards peter
