USB Servo Controller Question
Hi,
I'm trying to control the parallax USB Servo controller with python...
I can connect to the controller with over USB but I can't get the command string correct:
can anyone provide me with a valid example of the command string I write to the controller?
Chris Savage
Parallax Engineering
from serial import Serial s = serial('/dev/bstamp') s.baudrate=2400 s.stopbits=2 str_out = '!SCVER?\n' s.write(str_out) str_in = s.readline()str_in is !SCVER?\n
Not sure what I'm doing wrong here....
www.adamthree.com/index.php?page=files
which has a python module designed to control the Parallax Servo Controller
