Zero Resistance Amp meter (ZRA)
Hi,
I am looking for an easy way to measure milliamp current using a zero resistance method ( no Shunt).
Anybody have any idea where to look or start?
These are a ring that you run the wire through. It senses the magnetic field generated by the current flowing through the wire.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Chris Savage
Parallax Engineering
Wrap the wire several times through a ferrite core with a slot cut in it. Insert the Hall Effect into the slot in the core to measure the field.
Wrap the wire as many times as you need to get the sensitivity you need.
Of course this is only any good if you are not worried about suppressing or interfering with AC in the wire, but it works well for very low speed or DC.
Cardinal Fang! Fetch the comfy chair.
Rick
Correction!!! 6.5 digits
Post Edited (RickB) : 3/4/2009 6:59:05 AM GMT
- Stephen
