5v USB power supply suitability. and Why is the prop 3.3?
So does anyone know if a standard USB supply(as in power from a USB computer port) is clean and consistent enough to use as the main supply for 5v chips ect. with out an additional regulator and to the 3.3v reg for the prop?
I measured every usb port in my house with everyone being slightly different. I have never measured a whole bunch of 5v regulators to see how much variance there is. So I decided to ask.
Also anyone know off hand what the technical reason the prop is 3.3v instead of the seemingly more common 5v? I am sure there is a reason I just haven't found it yet.
TJ
TJ
2) The Prop is powered from 3.3V because of the maximum voltage of the manufacturing process used and to limit the power consumption and heat dissipation of the Prop. The Prop II will run from 1.8V internally although it will have 3.3V I/O pin drivers.
Happy to be corrected if I'm wrong. Its something I'd really like to know...
tubular
Absolutely correct. In theory a hub is perfectly within its rights to shut your power off if you draw more than you negotiate. In practice it never happens. Heck, I've seen a device draw 1A from a port and not even have the D+/- lines connected. It's ugly, but it happens. Same as these hard disks that use a dual headed cable, where they have one power/data port and another power port in parallel to give them 1A. Certainly not legal in the specifications, but everyone seems to be doing it.
Cardinal Fang! Fetch the comfy chair.
Which is precisely what happens to my USB powered protoboard when I plug it into the USB socket. The Electrolytic designed to smooth the power to the servos causes a nice instantaneous current pulse that causes most hubs or root hubs to scream "Overcurrent" and reset the port.
I have been shut down for drawing too much current. The internal USB hubs on the Mac monitor the USB ports and will send you a NastyGram message telling you to stop. It then shuts down the port to protect itself.
I have not seen this happen with external powered hubs though.
