Prop + ethernet functionality
I am in the process of trying to grasp embedded ethernet. Can someone that has done this on the prop tell me if the prop + enc28j60 can do something like the link below?
demo.netburner.com:81/INDEX.HTM
JMH
There's not a huge amount of space for webpage data. You could probably do everything but the video. I think the EEPROM can be replaced and could be upgraded to a 128K byte EEPROM. That might let you serve more information from EEPROM.
Does the prop interface run into a spi bottleneck problem?
--Steve
