High Voltage Waveform Controller
Hi,
I'm trying to design a voltage controller to impress an arbitrary, predetermined and programmed high voltage waveform, ~3000volts with, say, 50 to 100 nanosecond resolution, into an aqueous sample with a MOSFET switch. I was hoping that a microprocessor controlled PWM could provide me with the switching profiles, frequency and duty cycle, necessary. I'm currently considering a controlled feedback loop to increase the PWM / MOSFET duty cycle when the voltage is low and reduce the switching when the voltage starts to overshoot.
I had been looking at the BASICStamp, but now I'm seeing that it implements the PWM function differently than what I would have anticipated. Perhaps the answer could be BASIC Stamp with digital PWM circuitry added on, etc.
Is anyone here familiar with an existing solution? Suggestions?
Appreciate it.
The sum total of my electrical engineering is a passing familiarity with the fire extinguisher codes.
Appreciate it.
· -- Carl, nn5i@arrl.net
Is this not possible?
It'll be a little hard to feed the gates, since they too will be 1500 volts apart.· And you'd better be very sure they switch simultaneously, or one will blow.· This problem is magnified greatly if it's an analog amplifier instead of a switch.
I wish I could watch, from a safe distance of course.· Things like that never work the first time.
Finally, electrical isolation between your PWM logic and the HV side is also a good idea. Optos will be too slow, but there are digital isolators capable of 90Mbs and 5000V isolation. Analog Devices' ADUM2400CRWZ is an example.
A large transmitting tube was my first thought too.· 3Kv is the absolute maximum rating for a 4CX1000A, so I'd probably use something with a little bit of margin.· The 4CX3000A has a maximum rated plate voltage of 7KV in Class AB1 so it would probably be OK.· So would a 4-400A, which can handle 4Kv.
Somehow I doubt that kind of power-handling ability is required, though.· There may be other types, perhaps used in oscilloscope deflection amplifiers, that can handle high voltages at modest power.· I have no data sheets for those, though.
I note the requirement for 50 to 100 nanosecond response -- that is, 10 to 20 MHz response.· Will any microcontroller handle that requirement?· Certainly not any I've worked with, which however constitute a limited set.
Parts cost would be in the hundreds of dollars instead of the thousands of dollars for the exotic power amp tubes and coolers.
