Voltage inputs to BS21C and correlating voltage outputs
How would I go about converting 0-5 volt inputs into the BS21C into a similar 0-5 volt voltage output, modified by signals from my accelerometer? Any information regarding this topic would be a great help. Thanks a lot!
You can attach an analog to digital converter to a BS2 that has one or more input channels (that can be selected one at a time). The BS2 can read the analog voltage, modify it, and send the output voltage to a digital to analog converter.
Download the tutorial "Basic Analog and Digital" and read through it. Go to the main Parallax webpage, click on the Resources tab, select Downloads from the list presented, then Stamps in Class Downloads. You'll get a list of downloadable tutorials.
There are also Nuts and Volts Columns that would be useful to read.· From the Resources tab, choose Nuts and Volts Columns and browse the index for useful columns.
