Resonators
I have many 3-legged resonators in my parts bin. I know crystals are superior, but what is the schematic for using a resonator - 4mhz, 5mhz, 6mhz, 8mhz & 20mhz values? Crystals are good - resonators bad?
JMH
JMH
I would prefer someone with actual experience, not guesswork. Phil, have you physically used a resonator?
I am grateful for all of the support in this forum - really, just excellent group maturity and professionalism
JMH
Post Edited (James Michael Huselton) : 2/24/2009 4:21:38 AM GMT
JMH
Post Edited (James Michael Huselton) : 2/24/2009 4:18:15 AM GMT
JMH
I've used many a resonator with PICs and SXes but, until a few minutes ago, not with the Propeller. Just to double-check that I wasn't feeding you a bunch of blather, I plugged a resonator into my Prop Demo Board and grounded the center pin. I then loaded a color video demo. The program ran fine, but the video was not in color. This happens when the frequency is not accurate enough to provide a correct chroma clock and color burst.
I also tried it without the center pin grounded, and the Prop did not run at all.
Now are you satisfied?
Thanks for graciously testing this out. I just now duplicated your results. This issue can be put to bed now
JMH
Phils' resonator connection is correct, the center terminal goes to GND. You might also want to pay attention to the "XTAL" settings in the Propeller software depending on the frequency and load capacitance value of the resonator that you are using as these could make a difference with some resonators.
From page 29 in the Propeller Manual:
XTAL1 - 36pF load capacitance - 4 to 16 MHz Resonator
XTAL2 - 26pF load capacitance - 8 to 32 MHz Resonator
XTAL3 - 16pF load capacitance - 20 to 60 MHz Resonator
Beau Schwabe
IC Layout Engineer
Bottom line: Use Vss if you can make a short, direct connection; otherwise, Vdd should work just as well.
Post Edited (Phil Pilgrim (PhiPi)) : 2/25/2009 6:32:39 AM GMT
JMH
