Variable overwriting another variable
I'm new to spin so hopefully this isn't something really stupid I am doing wrong. The problem I am having is when I write to one of my variables it is actually overwriting a different variable.
This is my variable definition block:
This is where the temp variable is used:
The problem is instead of the number being assigned to temp it is sent to DOT. This has me stumped.
VAR long centerPos, servoPos, Dot long temporary, newPos, degMax, degMin byte Cog
PUB setDeg(servo, deg) temporary := (controller.getHighLimit(servo) - controller.getLowLimit(servo)) / DOT[noparse][[/noparse]servo] newPos := (deg * temporary) + centerPos[noparse][[/noparse]servo] servoPos[noparse][[/noparse]servo] := newPos controller.Set(servo, servoPos[noparse][[/noparse]servo])
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
My guess is your server argument is set to *1*, not *0*.
Always, for cases like this, please attach full code.
VAR
long centerPos[noparse][[/noparse]10], servoPos[noparse][[/noparse]10], Dot[noparse][[/noparse]10]
byte Cog 'Holds the cog that the controller was launched into
That may not be what is going on, but I think we need to see more code to know for sure.
{{ Output.spin }} VAR long centerPos[noparse][[/noparse]10], servoPos[noparse][[/noparse]10], Dot[noparse][[/noparse]10] long cheapfix, temp, newPos[noparse][[/noparse]10], degMax, degMin long reverseStatus[noparse][[/noparse]10] byte Cog 'Holds the cog that the controller was launched into OBJ controller : "MyServo32v3" PUB setup(pinStart, pinEnd) | pinrange {{Sets all pins between start and end to output and sets initial position to servo center. It also sets default end point limits to avoid servo damage. This must be called before servo START}} repeat pinrange from pinStart to pinEnd 'Preset ALL servo's to center position controller.Set(pinrange,1000) controller.setHighLimit(pinrange, 2250) controller.setLowLimit(pinrange, 225) PUB start {{Starts the Controller must be called AFTER setup and before all other commands}} controller.Start PUB setCenter(servo, pos) {{Set the center position of each servo. This becomes 0 Deg's}} centerPos[noparse][[/noparse]servo] := pos servoPos[noparse][[/noparse]servo] := pos controller.Set(servo, centerPos[noparse][[/noparse]servo]) PUB center(servo) servoPos[noparse][[/noparse]servo] := centerPos[noparse][[/noparse]servo] controller.Set(servo, centerPos[noparse][[/noparse]servo]) PUB setDeg(servo, deg) {{Sets the servo using degrees must be between degMax and degMin}} temp := (controller.getHighLimit(servo) - controller.getLowLimit(servo))/ DOT[noparse][[/noparse]servo] 'Calculate how many degrees per ms newPos[noparse][[/noparse]servo] := (deg * temp) + centerPos[noparse][[/noparse]servo] servoPos[noparse][[/noparse]servo] := newPos[noparse][[/noparse]servo] controller.Set(servo, servoPos[noparse][[/noparse]servo]) ' PUB setDot(servo, deg) {{This tells the controller how many degrees of travel the servo is able to move. This must be adjusted if the end point limits are changed}} Dot[noparse][[/noparse]servo] := deg PUB getPos(servo) : position {{return the current position of the servo}} position := servoPos[noparse][[/noparse]servo] PUB setPos(servo, pos) {{Set the position of the servo to a specific point. The controller will still stay between the endpoints}} servoPos[noparse][[/noparse]servo] := pos controller.Set(servo, servoPos[noparse][[/noparse]servo]) ' PUB increasePos(servo, val) | tem {{Increase the servo position by a specific ms value}} tem := servoPos[noparse][[/noparse]servo] + val servoPos[noparse][[/noparse]servo] := tem controller.Set(servo, servoPos[noparse][[/noparse]servo]) ' PUB decreasePos(servo, val) | tem {{Decrease the servo position by a specific ms value}} tem := servoPos[noparse][[/noparse]servo] - val servoPos[noparse][[/noparse]servo] := tem controller.Set(servo, servoPos[noparse][[/noparse]servo]) PUB setHighLimit(servo, value) {{Sets the High END POINT of Servo}} controller.setHighLimit(servo, value) PUB setLowLimit(servo, value) {{Sets the low end point of servo}} controller.setLowLimit(servo, value) PUB reverse(servo, status) reverseStatus[noparse][[/noparse]servo] := statusPost Edited (Mcadieux) : 2/24/2009 5:48:11 AM GMT
If you want help, you have to post your entire program, not just output.spin. The problem might lie in the code that calls the methods in output.spin.
{{ Output.spin }} VAR long centerPos[noparse][[/noparse]10], servoPos[noparse][[/noparse]10], Dot[noparse][[/noparse]10] long cheapfix, temp, newPos[noparse][[/noparse]10], degMax, degMin long reverseStatus[noparse][[/noparse]10] byte Cog 'Holds the cog that the controller was launched into OBJ controller : "MyServo32v3" vp:"Conduit" PUB setup(pinStart, pinEnd) | pinrange {{Sets all pins between start and end to output and sets initial position to servo center. It also sets default end point limits to avoid servo damage. This must be called before servo START}} vp.share(@Dot, @newPos) repeat pinrange from pinStart to pinEnd 'Preset ALL servo's to center position controller.Set(pinrange,1000) controller.setHighLimit(pinrange, 2250) controller.setLowLimit(pinrange, 225) PUB start {{Starts the Controller must be called AFTER setup and before all other commands}} controller.Start PUB setCenter(servo, pos) {{Set the center position of each servo. This becomes 0 Deg's}} centerPos[noparse][[/noparse]servo] := pos servoPos[noparse][[/noparse]servo] := pos controller.Set(servo, centerPos[noparse][[/noparse]servo]) PUB center(servo) servoPos[noparse][[/noparse]servo] := centerPos[noparse][[/noparse]servo] controller.Set(servo, centerPos[noparse][[/noparse]servo]) PUB setDeg(servo, deg) {{Sets the servo using degrees must be between degMax and degMin}} temp := (controller.getHighLimit(servo) - controller.getLowLimit(servo))/ DOT[noparse][[/noparse]servo] 'Calculate how many degrees per ms if reverseStatus[noparse][[/noparse]servo] == 0 newPos[noparse][[/noparse]servo] := centerPos[noparse][[/noparse]servo] +(deg * temp) if reverseStatus[noparse][[/noparse]servo] == 1 newPos[noparse][[/noparse]servo] := centerPos[noparse][[/noparse]servo] - (deg * temp) servoPos[noparse][[/noparse]servo] := newPos[noparse][[/noparse]servo] controller.Set(servo, servoPos[noparse][[/noparse]servo]) ' PUB setDot(servo, deg) {{This tells the controller how many degrees of travel the servo is able to move. This must be adjusted if the end point limits are changed}} Dot[noparse][[/noparse]servo] := deg PUB getPos(servo) : position {{return the current position of the servo}} position := servoPos[noparse][[/noparse]servo] PUB setPos(servo, pos) {{Set the position of the servo to a specific point. The controller will still stay between the endpoints}} servoPos[noparse][[/noparse]servo] := pos controller.Set(servo, servoPos[noparse][[/noparse]servo]) ' PUB increasePos(servo, val) | tem {{Increase the servo position by a specific ms value}} tem := servoPos[noparse][[/noparse]servo] + val servoPos[noparse][[/noparse]servo] := tem controller.Set(servo, servoPos[noparse][[/noparse]servo]) ' PUB decreasePos(servo, val) | tem {{Decrease the servo position by a specific ms value}} tem := servoPos[noparse][[/noparse]servo] - val servoPos[noparse][[/noparse]servo] := tem controller.Set(servo, servoPos[noparse][[/noparse]servo]) PUB setHighLimit(servo, value) {{Sets the High END POINT of Servo}} controller.setHighLimit(servo, value) PUB setLowLimit(servo, value) {{Sets the low end point of servo}} controller.setLowLimit(servo, value) PUB setReverse(servo, status) reverseStatus[noparse][[/noparse]servo] := status{{main}} VAR long stack[noparse][[/noparse]10] long temp CON _xinfreq = 5_000_000 _clkmode = xtal1 + pll16x OBJ controller : "ServoController0.6" PUB Main controller.setup(1,1) controller.start controller.setCenter(1,1000) controller.setDOT(1, 160) repeat controller.setCenter(1,1000) waitcnt(clkfreq * 3 + cnt) controller.setDeg(1,45) waitcnt(clkfreq * 3 + cnt) controller.setCenter(1,1000) waitcnt(clkfreq * 3 + cnt) controller.setDeg(1,-45) waitcnt(clkfreq * 3 + cnt)The MyServo32v3 object is just your standard Servo32v3 object. I deleted cheapfix temporary and made temp back to a local variable and it seems to work fine now. I may have just been doing something stupid last night. Thanks for trying to help, sorry I was brain dead about posting code last night.
Glad you figured it out.
- Bjarne Stroustrup
