Whats the "Flops" On the propeller
How many
Visit my site -> [url=Http://www.rawcircuits.com]www.rawcircuits.com[/url]
Post Edited (grasshopper) : 4/10/2009 2:52:59 AM GMT
Flops is going to be almost meaningless because the chip is just not a good fit for that.
80 MHz / 4 clocks minimum per instruction * 8 cores = the 160 MIPS you've probably already seen.
John Abshier
Have you read the documentation, the Propeller Manual, the datasheet for the Propeller, the documentation for the floating point object? All that information is there, the number of clock cycles for each instruction, the approximate time each floating point subroutine takes to do its job, etc.
