B47AV PSOM.01 eeprom chip for ford speedometer
I have a friend that repairs odometers and does restoration for classic cars. He has one that needs a new eeprom because the digital output says error.
I have a few chips and he is going to bring the board over on Sunday so I can figure out the pinout on the 8 pin DIP. At least the power and ground pins.
I want to change the data to match the actual mileage of the cars odometer, he has chips that do work but the mileage is really high and the only person he knows wants three hundred to make the modification.
Does anyone know if this might be possible to do, is the chip typically a standard eeprom from one of the manufactures so one can read the data and write new data?
I have googled a bit and I see some say the clock chip has to be changed but he has many other eeproms that work fine when installed but have the wrong mileage.
I have also read some about programs that can read and modify the eeproms but why do that when i have a stamp.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
All that to say, changing the contents can be done; but without the unlock code and timing specifications, it's next to impossible and probably borders on illegal.
DJ
Post Edited (davejames) : 2/21/2009 6:06:58 PM GMT
