Forcing 16 Bit Constants
@ Terry;
Terry I am using SX/B, and in calling some routines, I require 4 Paramerters, one pair of which is from a selection of 16 bit pre-labeled constants.
When I assign (EQU) a 16 bit constant·to a label, and the leading (MSB) portion of that constant happens to be 00, then the compiler appears to treat it as an 8 bit constant, and throws an "invalid number of parameters" error. I know there are work-arounds possible, but can this be circumvented in the compiler?
Cheers,
Peter (pjv)
ReadFram __Param1, __Param2, 0, 0 ' direct assignment works fine Address1 con $1234 ReadFram Address1, 0, 0 ' also works fine Address2 con $0034 'intended as a 16 bit constant ReadFram Address2, 0, 0 'throws a hairy
Cheers,
Peter (pjv)
Until the compiler is modified could you declare your routine as using 3 or 4 byte parameters and then do this?:
SUB READ_FRAM ASM JB __PARAMCNT.2, @RF_Start MOV __PARAM4, __PARAM3 MOV __PARAM3, __PARAM2 CLR __PARAM2 RF_Start ; code here ENDASM ENDSUB-- I'm asking/suggesting for my own edification.
As I said, there are work-arounds, but that is so inelegant, and somtimes I already use up the __ParamCnt spot, so that is not available.
I'm hoping something simpler is possible.
Also, sometimes the constants are calculated at compile time, and one is not aware that the MSB portion is zeros.
Cheers,
Peter (pjv)
If I recall correctly, there was such a request in the beta forum,
and the suggestion was made to allow
subname [noparse][[/noparse]type] var/constant, ....
where type is optional and could be word/byte
so sxb could convert the variable/constant to the specified type.
regards peter
So this would compile to a single byte:
SomeCon CON $FF
But this would be a word:
SomeCon CON $0FF
as would this
SomeCon CON $FFFF
p.s. My workaround has been this:
Which isn't awful, but isn't great either.
SomeSub SUB 3,4,Byte,Word,Byte
This will compile to always make the 2nd parameter a WORD by setting __PARAM3 to zero if needed. And the last byte is optional and will be __PARAM4.
I just never got to it.
I will look into doing this change, but I don't want to keep changing stuff while Jon is working on the documentation. Maybe after 2.01 is released ?
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Post Edited (Bean (Hitt Consulting)) : 2/20/2009 12:46:52 AM GMT
I don't think this needs be directly related to optimization for multi-byte/multi-word sub/func calls. If I remember that discussion related as much to optimizing code and obviating the need for paramcnt in mixed var cases without the user having the manually clear the upper byte before the call.
If you·don't need the full 16bits·range for·your constants,
you could declare them with b15 set.
addr1 con $9234
addr2 con $8034
and simply clear __param2.7 upon function entry.
You don't need to use __paramcnt then,
nor do you explicitly need to clear __param2
if the actual value <= 255.
regards peter
Post Edited (Peter Verkaik) : 2/20/2009 7:49:19 AM GMT
Thanks for your thoughts and inputs.
What I was hoping for was something along the lines of what Zoot is saying.... a simple ability to force the compiler to treat a constant as a 16 bit number, including calculated constatnts, regardless of the value of the MSB.
And PeterV; that is actually a clever and not too costly way of a work-around.
Cheers,
Peter (pjv)
Bean.
But if you specify a BYTE parameter and use a WORD is doesn't error (as it should).
I will fix that ASAP.
Bean.
My own work tries to not rely on paramcnt for funcs/subs too much as the code overhead can really add up (if you are loading up, say, three params plus paramcnt, right there that's 8 instructions before the CALL itself).
I guess I could just use the LSB... That would probably be better.
Bean.
Post Edited (Bean (Hitt Consulting)) : 2/21/2009 7:05:34 PM GMT
should truncate to·the LSB part.
regards peter
Many of my library subs/funcs require word parameters
and so it would make sense that I add WORD,WORD to
the declaration.
Many of these subs/funcs are also called from within
the library by using
· subname __param1,__param2,__param3,__param4
which simply compile into
· call @__subname
Now, when adding the WORD,WORD to the declaration
the calling should change to
· subname __wparam12,__wparam34
However, this compiles into
· MOV __PARAM1,__WPARAM12_LSB
· MOV __PARAM2,__WPARAM12_MSB
· MOV __PARAM3,__WPARAM34_LSB
· MOV __PARAM4,__WPARAM34_MSB
· call @__subname
so there are 4 redundant instructions added.
Can sxb check for __wparamx and leave out the redundant
MOVs if the __wparamx is in the correct place?
regards peter
Cheers,
Peter (pjv)
