Measure Cable TV Signal Level
A colleague of mine has got a rats nest of RG-58 cable & splitters in his house (installed before he moved in). He's got cable TV, and he's having signal level problems at some, but not all, of the outlets. He's not sure if the signal levels are too high or too low. Is there a reasonable (low) cost way of measuring the signals, even if it's not especially accurate? Much of the wiring is behind walls, so tracing the wires by hand is out of the question.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
More likely, I think, is that he's getting ghosting on the screen because RG-58 isn't the right kind of cable for most video systems.· RG-58 is 50 ohm cable, while the standard for video systems is 75 ohms (RG-59 or RG-6, usually), and most devices like monitors, VCRs, etc. are designed to present a 75 ohm termination.· An impedance·mismatch will cause signal reflection at every juncture. which can in turn cause ghosting, sync problems, and other annoyances.
· -- Carl, nn5i@arrl.net
Craig Eid
www.TriadRD.com
Unless your cable is analog (unlikely these days), there really isn't a fair comparison against the 64-QAM, 128-QAM, or 256-QAM digital signal that is going to be a "cheap" solution.
Beau Schwabe
IC Layout Engineer
Cable······ Imped· Max Oper··· O.D.·········································
Type······· (Ohms)· Volts····· Inches················
RG-6A/U··· ·· 75··· 2,700····· 0.332·····
RG-58C/U···· 50··· 1,900·· ·· 0.195·····
RG-59B/U···· 75··· 2,300····· 0.242··
Craig Eid
www.TriadRD.com
Post Edited (Craig Eid) : 2/19/2009 6:49:45 AM GMT
Leon
{commonly used back in the early '90's}
(shutter)
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
That's a cool way to do it... even better if your cable modem also serves as an IP phone (<- just more information).
Realize though that with "192.168.100.1" you are talking directly to your cable modem, and not some website. If you come across a cable modem that does not work, then look on the box for an alternative IP address to use.
Beau Schwabe
IC Layout Engineer
Cool, though.· I didn't know cable modems had a IP address at all on the LAN side, much less what that address might be.
Anyone know whether it works with D-Link cable modems?· Errr -- not meaning to hijack the thread.
Try this address on your LinkSys modem: 192.168.100.1/RgConnect.asp. It's accessible from the modem's home page via the "Connection" link.
Keep an eye out for coax "taps". They work the same as a splitter...except that a splitter takes an input and makes 2 outputs at 3dB down.
A 4way splitter does worse....1 input and 3 outputs...1 output is 3dB down and the other two outputs are 6dB down...so even worse.
If you can find taps, you have an inline loss with a tap off the side that is usually only 1dB down, even though the in to out loss may be 20dB (used in setting up distribution systems).
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
On the cables you still need, start changing connectors until signal gets better. (When has the cable guy ever showed up to your house without changing the cables or connectors?) There is a calculable length-loss in the cable but "controllable" RF signal strength over cable is ultimately a function of the mechanical connection quality. Unless the cables have been nicked, cut or moisture compromised, they are probably predictable in terms of loss and there is nothing you can do about it. Rule of thumb says a "good" connector is a 1dB hit on signal strength in the math. Few connectors have a rated life span of more than five years.
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
