Integrating tv.spin with a ntsc signal
I'm using a chip to decode vertical sync, composite sync, odd/even line and burst/back porch signals. I would like to display the ntsc signal, from a video camera, over the top of the tv and put two text lines from the tv.spin program on the bottom of the screen.
I have been unable to get a solid sync between the ntsc signal and the tv.spin signal. The ntsc signal sets the vertical sync and the tv.spin signal drifts across the bottom of the screen and then jumps back.
Can anyone point me to a working example?
