PROP Device VIA USB ( PROPPLUG) to another PROP Device- Problems
HI,
I am using the PROP PLUG on each of my 2 PROP DEVICES, I have the standard RESET , GND, RX & TX lines connected to the prop plug, I have a USB TYPE A CONNECTOR ( at both ends) connected to both prop plugs.
PROPCHIP --> PROPPLUG --> (TYPE-A PLUG - CABLE - TYPE A PLUG) --> PROPPLUG -->PROPCHIP
I cannot get the two prop devices to communicate, the RX & TX LEDS don't even light up!
BUT..
With each of my prop devices I can ( without any issues using the above cable and connections) ..
1) Load the propeller via the PC using spin,( no probs)
2) debug/communicate with the prop terminal on the PC
3) Use a REAL-BASIC Application ( that I am developing at the moment) to send and receive serial data ( via the MAC).no probs.
4) use a serial terminal application on the MAC for debugging/sending commands etc ( no probs)
What i am trying to say is that I have no problems talking to ANY of my prop devices via USB to either MAC OR PC, but..
I cannot get two props to communicate.
Q1) Is this something to do with the prop plug or the UART in the PROP being/not being a DTE or DCE ?
I am using extended FD serial for all my comms ( at 57600 baud).
I hope i explained this clearly???
thanks
Dave M
BUT..
thanks
Dave M
If you are doing that, why use the prop plug at all? Just build a 3 wire prop-plug style crossover cable and use the standard TTL serial.
Cardinal Fang! Fetch the comfy chair.
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
Thanks for that,
I already have my device(s) built with USB "Ports" to allow firmware updating and Serial coms via a PC or a MAC ( all of which works beautifully).
But I have expansion ports to allow other protocols such as RS485.
thanks
Dave M
· Home of the MultiBladeProps (SixBladeProp)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
My cruising website is: ·www.bluemagic.biz
I will leave the use of a propplug to only function as a port for uploading firmware and for serial comms to a PC or MAC, These two features work really well at the moment .
I think RS485 is the best way for multi-prop WIRED communication.
I actually use AEROCOMM modems for multipoint serial comms as well.
regards
Dave M
