Holding an SX in Reset
Zoot
I have a project where an SX pin controls the enable line of a 5v 2A regulator (allowing the micro to turn power on/off to the subsystems). The enable line has a pulldown so that when the SX is off or in reset, the line is hold low (power off) and is only brought high (power-on) when the SX pin is an output and high.
I want to save some wiring and party-line setup back to the main host, because the host also needs to be able to shut power down to the subsystem. So my thought is just to let the host reset the SX and hold it there when it needs to (which would also make the enable line an input and let it be pulled low). The host needs to be able to reset the SX anyway.
Is there any reason not to let the host hold the SX in reset for an extended time? I'm talking minutes or half-hours, not days or weeks. Also, does the SX use less power when held in reset?
Regarding power consumption during RESET, there is probably not much saving as the SX clock continues to run while the RESET is low, so all that is gained is non-clocking of the logic.
Cheers,
Peter (pjv)
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Sounds Like You have a Cool project. 70lbs,
Cool Dude!
___________$WMc%_____________
The Truth is out there············································ BoogerWoods, FL. USA
Please excuse the newbieness [noparse]:)[/noparse]
