Ampliflying a I/O pin signal
I have some DC motors that usually run on 9v. Can someone show me a circuit that I can amplify the 5v signal from the output pin to 9v so it can drive the motor? Or is that possible?
Dan Taylor
Dan Taylor
- Stephen
I have some random transistors and·a Operational Amplifier IC 324.
By the way thanks for posting!
Dan Taylor
I will try that and get back to you on how it goes.
Thanks!
Dan Taylor
· -- Carl, nn5i@arrl.net
I forgot to mention that I am only using one motor for the back wheels. You apply voltage and it goes forward and reverse the voltage and it goes backward. The front wheels turn so that the car can turn...
The front motor is the same, apply voltage to one of the wires and the wheels turn one way. Reverse the voltage and the wheels turn the other way.
So I can't apply one of the wires of the motor to positive or negative cause I need them both and have to apply positive to both wires at different times quite frequently.
In my bs2 program I am just sending low to one of the wires and high to the other to go forward and backward.
But again the positive 5v from the output pin is not powerful enough to drive the motors.
Dan Taylor
I am not sure how many Amps the motors can run on. They don't say,
I am also not sure how the H-Bridge circuit works, so I don't think I am ready for a circuit board yet. Thank you though! I may take you up on that. But is that one of the only ways? Is there any other options?
Thanks for the info!
Dan Taylor
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
http://en.wikipedia.org/wiki/H-bridge
It's basically just a circuit that switches the polarity of the motor leads. And yes, measure the current.
Couldn't I use relays instead of the H-Bridge Circuit?
Dan Taylor
Relays are relatively slow. You don't want them to have to switch full current because that's harder on the relay contacts than switching them when the current is off not to mention that the current when you reverse a motor is pretty high.
Could you explain how?
Dan Taylor
Is that abnormal?
Dan Taylor
So what do you call expensive for the L298 chip?
Cause I don't have much room for a circuit board. Though I probably could fit it.
Or maybe I could just build it on the breadboard.
Dan Taylor
Post Edited (Dan Taylor) : 2/16/2009 5:17:14 PM GMT
Dan Taylor
There is L298N, L298PN... Not sure which one is the one that would work for what I am doing...
Dan Taylor
