direction finding
I once got close getting a pilot's license. I really loved the experience. The most amazing fact that I learned was that if I got lost... all I had to do was follow my local AM radio station home.
Is this sort of thing ever used in robotics or is there too much reflection or too much hardware required to be useful?
Rich
ILMP
Rich
ILMP
The principle is basically a simple one, although it can get a bit involved in implementation.· My RDF unit will weigh about a pound or so, not including the antennas, which are 19" whips mounted on a metal disk two feet in diameter.· I used a trash-can lid for the disk.
I'm working at 146 MHz.· For AM at 1 MHz, the antennas would have to be 100 times bigger for the same performance·-- so you should home on an FM station (between 88 and 108 MHz)·instead, or perhaps a NOAA weather station in the 162 MHz region.
SRLM, small planes don't get thousands of miles off course.· They don't have that kind of range.
Rjo, how do you intend to home on a station to get home?· Do you have a radio station in your house?· Having one a mile or more away won't do you the least good unless the people there will call you to come get your robot.
· -- Carl, nn5i@arrl.net
If you did have a wireless link and connected it with a analog to digitial converter... you could have your robot move in random directions until it found one with the strongest signal... at least
that way you could make your robot find its way to your desk or something [noparse]:)[/noparse]
