Sandbox has slipped to the bottom?
Why was the Sandbox moved? It's now the only technical forum that's separated from the others by non-technical forums (i.e. "Test..." and "Support..."). (If I were the Forum Czar, it would be at the top, to catch non-Propeller posts that end up there just because it's the first forum in the list. Doing so would save the moderators a lot of work. Now it's even harder to spot than before.)
Not sure why that happened. I will look into it and see if we need to make any adjustments.
Chris Savage
Parallax Engineering
Jim
Parallax IT Dept.
Chris Savage
Forum is singular, fora is plural (like datum and data).
Post Edit -- links added
http://www.merriam-webster.com/dictionary/forum
http://www.merriam-webster.com/dictionary/datum
Post Edited (PJ Allen) : 2/12/2009 7:32:48 PM GMT
Jim
Parallax IT Dept.
A logical order (to my mind at least) is the following:
Propeller
BS
SX
Javalin
Stamps in Class
Hydra
Robotics
Sensors
Sandbox
Completed Projects
Support
Test
This way, it groups the microcontrollers together, then the specific applications, then the general forums, and then support.
BS
Javalin
SX
Prop
Or (If I understand the dates properly):
BS
SX
Javalin
Prop
