BYTEMOVE between cog and hub
Hi All,
Long time no post :P
Anyway. I have an application where I am collecting data from x number of 8bit shift registers into a cog and once done I need to copy all of it into an array in the hub.
In the hub I have the following:
byte S88_Register[noparse][[/noparse]128].....holds 128bytes of data, ie. 128 shift registers
byte S88_Changes[noparse][[/noparse]128]....a '1' bit is placed in the location of any bits that change from 1 sample of S88_register to the next
long S88_number_of_modules...the number of 8bit shift registers I am collecting data from to put into S88_register
And in my cog I have the following (all longs as they are declared on the 'PRI' line of code)
S88_reg[noparse][[/noparse]32]....128 bytes containing the new shift register values.
cur_reg, i, temp_register.....working variables.
Here is my code, hope it makes sense! (Ignore the timing and clock cycles, thats not what im stuck on...at the moment [noparse]:D[/noparse]
My questions are:
1) See the **Is this ok?*** comment in the code above [noparse]:)[/noparse]
2) The last 3 lines, where I compare and update.
Can I replace that with:
I am a bit confused with this last question because the manual keeps referencing the source and destination as address' in main memory. I want to copy 128 bytes from cog memory to hub memory... (Ie S88_reg to S88_register)
Thanks for taking the time to read this!
Alec
-Alec
Velden in N scale
Post Edited (Basil) : 2/11/2009 8:17:54 PM GMT
'********************************* 'Get data from S88 shift register '********************************* repeat cur_reg from 0 to S88_Number_of_modules temp_register~ ' clear temp_register repeat 8 Wait_us(40) temp_register <<= 1 temp_register += ina[noparse][[/noparse]S88_DATA] 'Clock data into temp_register outa[noparse][[/noparse]S88_CLOCK]~ Wait_us(40) outa[noparse][[/noparse]S88_CLOCK]~~ BYTEMOVE(@S88_reg[noparse][[/noparse]cur_reg],@temp_register,1) 'Copy the 8 LSBits into the next byte in S88_reg ***Is this ok?*** outa[noparse][[/noparse]S88_LOAD]~ outa[noparse][[/noparse]S88_RESET]~ outa[noparse][[/noparse]S88_CLOCK]~ '********************************* 'Compare new data with previous and record changes '********************************* repeat cur_reg from 0 to S88_Number_of_modules S88_changes[noparse][[/noparse]cur_reg] := S88_register[noparse][[/noparse]cur_reg] ^ BYTE[noparse][[/noparse]@S88_reg][noparse][[/noparse]cur_reg] S88_register[noparse][[/noparse]cur_reg] := BYTE[noparse][[/noparse]@S88_reg][noparse][[/noparse]cur_reg]
My questions are:
repeat cur_reg from 0 to S88_Number_of_modules S88_changes[noparse][[/noparse]cur_reg] := S88_register[noparse][[/noparse]cur_reg] ^ BYTE[noparse][[/noparse]@S88_reg][noparse][[/noparse]cur_reg] BYTEMOVE(@S88_register,@S88_reg[noparse][[/noparse]cur_reg], 128)
Alec
-Alec
Velden in N scale
You're probably confusing the notion of cog memory with the notion of using a cog to run the Spin interpreter to interpret some Spin code.· In the latter case, there's no user data in cog memory (other than the special function registers), only the Spin interpreter itself.
Do you spot any problems with my method of storing bytes? Its the first time ive dealt with anything other then longs.
-Alec
Velden in N scale
Does that mean my array S88_reg[noparse][[/noparse]32] which I thought would be in hub memory can now be declared in the VAR section as BYTE S88_reg[noparse][[/noparse]128]
Not that it would make much difference I guess...
-Alec
Velden in N scale
