Power supply suggestions for prototyping on the PDB in a small space
WBA Consulting
I am finally making headway on my toolbox PC so that I can keep all of my Basic Stamp prototyping parts in one location. Also, I can pick it all up and power it anywhere I have AC or 12V. Anyhow, I am trying to decide on what to use for my project power supply so that I don't become limited.
Currently, I have a 12v, 3.5A brick that powers the LCD and AMD Geode "ION" single board computer. Per specs, the two combined should never draw more than 2.5 amps. It can also be powered with a 12V lighter adapter. I typically use 3.3, 5, 9, and 12 volt supplies during prototyping.
I am thinking of doing one of the following to make power available for my projects:
1) Use another 12v brick along with three individual power supply circuits for 9v, 5v, and 3.3v.
2) Tap off the existing 12v brick and use two adjustable 3-12v power supply circuits.
3) Use an open frame type power supply off of AC that has 12, 9, and 5 volt outputs and make a shell for it.
4) For low current 5V apps, I can harvest the USB power from the SBC.
Any suggestions?
The picture is my toolbox PC with the LCD, ION, PDB, wireless, mouse, and keyboard. The case is from harbor freight. You can see I have a good amount of room left to play with for part storage and power supplies.
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Any suggestions?
Andrew Williams
WBA Consulting
Why make it portable if your stuck to a wall with a wire?
Andrew Williams
WBA Consulting
I'd also consider a laptop battery as well... If you have an old laptop you can just swipe that one and use the laptop to keep it charged.
Of course this makes me want one of those LCD panel mount voltmeters that can be switched between them.
Andrew Williams
WBA Consulting
