ANNOUCEMENT: CONTEST > Recession Proof Protoboards < Congrats! Cole Logan
Oldbitcollector (Jeff)
It's UNOFFICIAL contest time again, this time with a twist!
We all know that some pretty incredible stuff can be done with the Propeller using only
a few minor parts. I'd like to suggest that the Propeller Protoboard is Recession Proof!
Here's the contest:
Using only a Propeller Protoboard and items found in a typical home I want to see what cool
things can be done without that shop full of electronics stuff that we're all sitting on.
That's right, the typical household doesn't have drawers full of resistors, capacitors, and connectors.
Here's what you are allowed to have:
* 1 Propeller Protoboard (with USB cable and/or Propplug if applicable) (no Accessory Kit!)
* A PC to program it. (Don't most typical households have a computer these days?)
* A power source. (I'll bet you could find a compatible wall-wart in any home.)
* Hookup wire. (22 gauge wire isn't in every home, but we'll give you this one, even alligator clips.)
* Soldering pencil and basic tools are also allowed.
* 1 *Freebie* A single electronics item retail price valued .99 or less.
* Anything found in a typical home. (other than yours. [noparse]:)[/noparse]
You have two weeks to come up with/and create either something new or duplicate existing
demos and project using only items above and found in a "typical" home. (think: grandma's house)
Rule addendum: NO GUTTING Household electronics for parts! You know that grandma would
be upset if her TV quit working because you scavenged resistors from it! [noparse]:)[/noparse]
You must have photos to prove it works, (no theoretical drawings here, it must work.)
Video is even better.
Winner gets two USB Propeller Protoboards mailed to them. I'll try to ship internationally as well.
My son and I will play judges. We're looking for creativity and ingenuity.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 2/23/2009 3:14:48 AM GMT
Here's the contest:
OBC
Propeller project without using electronic components.
I have the board...
Roger
This is a really fun idea. Thanks OBC!
Whit+
@mctrivia: Most households have spare lights, bulbs, even flashlights.
Can't say more than this as I don't want to spoil good ideas.
Let's just say that much more is possible than you think.
OBC
Does taking vga & ps2 connectors from old computers qualify (even grandma's have them!) - that's how I obtained my vga connector - remove the plastic that guides the pins if they dont quite fit and fit the plug while soldering because you will need the connector to be slightly up off the pcb.
You are also correct in the walwart supplies - look for one with low voltage 6-7V preferably. If higher, then lower amperage is better, because they are unregulated and the voltage increases with lower current. Make sure it is center positive.
· Home of the MultiBladeProps (SixBladeProp)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
My cruising website is: ·www.bluemagic.biz
That borders on shaky ground.. Don't overdue it.. [noparse]:)[/noparse] My Grandma never kept old computers around. [noparse]:)[/noparse]
Be imaginative gang.. I promise it can be done! [noparse]:)[/noparse]
OBC
Already impressed with the concept from a creative mind.
Hope to be by the entrys.
OBC: Do you ever spend any time inside said Box
Roger
1- Massive collection of spare change
1- Individual with a drivers license
1- Car
Therefore, can these common household items be used to acquire more items? I'd guess not, just wishing ... Anyway, what about 'broken' items? I'm sure that most households have lots of common broken items, notably broken headphones, flashlights, kids toys, etc... Are these valid? I'm sure 'grandma' wouldn't mind if I took them off her hands!
Sorry, the only spare change is .99 for a single electronic item. [noparse]:)[/noparse]
OBC
We can only but 1 item, at < $1.00 and can't use resistors or caps ? it's got to be what is at nan's house?
and has to be protoboard, with no add-on, so can't have TV out OR VGA out?
Jim
Speaking of MacGyver. Who said we don't have any resistors or caps? I'm sure the average Granny's kitchen and sewing room contain everything required to make capacitors, resistors, microphones, speakers/sounders, moisture detectors etc. Coils, inductors are covered as we have some hook up wire on the table.
That's hilarious!
It might be the Information Age but the Eon of Ignorance has yet to end.
This is what I mean, are we allowed?
So this means making capacitors out of wax paper, rolled to contain the dielectric, and dipped in candle wax, kind of things?
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
LOL!!!
Fun OBC. Not sure how you come up with these, but I'm glad you do!
I know that TV out can be achieved... [noparse]:)[/noparse]
Don't overlook the parts that are all ready in front of you.
A historic look at electronics and the theory behind why things work might also be helpful.
OBC
most people have Silver nitrate sitting around right? none on my family is normal so I though I would ask :0
also, was the ruling no items even broken ones? I have an old tube radio that is begging to be part prop....
I'm too busy, but this is a great idea OBC
Beau Schwabe
IC Layout Engineer
Hmm.. I doubt that many grandparents kept an old tube radio, but perhaps it was possible. Don't overdue it.
(It'll take a lot of the intended challenge out.) The intention here is to cut off access to typical electronics
parts.
Silver nitrate.. Not sure that would have been found in the medicine cabinet or under the sink.
If you tinker here, please be sure and take appropriate precautions.
OBC
Yes, I agree here, I've found extra RCA cables when I needed them.
Same drawer with the extra phone lines and batteries.
OBC
Single DIP and related parts removes some of the challenge from this one..
OBC
"Sure, it's in spirit with the contest, but it will cost you a few points in the judging behind
someone who simply used a single part with a retail value under .99"
OBC
