System clock as 7 day to 24Hour real time clock?
If there is a loop that is running perpetually, why can't the system clock be accessed each iteration and update a running 7 day 24hour clock for setting timers etc? Looking at real time clock IC's, it seems they are crystal based as well, so whats the difference in using the Prop to maintain it's own internal clock versus a dedicated I2C clock IC?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Nyamekye,
If having a human set the time on start up is not a problem then there is no reason not to use the prop as a clock.
Chris Savage
Parallax Engineering
