Update firmware via gsm
Hi all,
I'm putting the finishing touches to a commercial prop based app. and I would like to include a facility where I could remotely update the firmware (eeprom file) using mobile phone (cell phone) technology.
Has anyone done anything similar and if so, any suggestions as to what is involved, code wise, external components, problems/issues etc?
Paul
Paul
The only way I can think of to do it safely, is to have add a second EEPROM where you can put the new downloaded code, until it's received with checksum, and check the completed transfer for errors, then program the main EEPROM with this new code.
obex.parallax.com/objects/321/. I haven't tried it myself though.
Remember you don't want to write to EEPROM often for months or years on-end as they may wear out [noparse][[/noparse]10's or (typically) a 100 thousand write cycles for standard parts]. But that probably won't be an issue. If it is; there are some high-end flash memory cards that have "wear leveling" and/or error correction capabilities built-in. From previous posts I've seen, it seems fairly simple to use the likes of an SD card with propeller for storage.
Regards, David
As an alternative, the bootloader could download the program (sans bootloader copy) in to RAM and store it in EEPROM at an offset address from the space the bootloader occupies. Then, upon reset, the same check for BREAK; only this time, if it sees none, it reloads RAM from the offset EEPROM, zeroes the leftover space at the top of RAM, and starts the cog at the first RAM location. I've used this latter method, and it works.
http://prop.aigamez.net/
I have not yet writen the code for the prop to download but I have notes on the pages use here
http://forums.parallax.com/forums/default.aspx?f=25&m=324680
but you'd need some HUB-RAM space for your GSM + Bootloader + MD5 data space, plus any spin in required for glueing together, plus you'd have to make sure the ram buffers were high up, and not in where the overwritten new code would be.
which is why I suggested the extra / or upper EEPROM as JetFire suggested, just to safeguard any code currently in hub-ram
Typically, the upper end of a program whose code and variables use 32K will be zero anyway, so this can be zeroed when the program is offset-loaded into RAM from EEPROM. At least that's the way I do it. My bootloader uses no hub RAM at all. I'm unfamiliar with the GSM code requirements, though, so perhaps this is a killer, space-wise. As to MD5, there are sure to be less involved, but nonetheless adequate, redundancy checks that could be performed using cog memory. But even with MD5, there are 16K bytes of cog RAM available, spread across 8 cogs and accessible with minimum-footprint ASM accessor routines that can use a few bytes of upper hub RAM for comms.
thanks for all your advice. I have limited 'knowledge' in relation to spin and practically zero in relation to asm. Anything I have done to date is with a lot of help from this forum. The app I refer to uses fsrw, fullduplexserial and basicI2C. I cannot say that I understand everthing about these objects, but I have 'managed' to get them to work together. I have managed to get the program update itself from the SD card, but I just thought that it would be cool to upgrade via GSM (and easier/better for me to monitor/control the upgrades).
Paul
I've been otherwise occupied since I posted my request for help. Again thanks for all the useful advice, however could anyone advise as to a suitable gsm card/module/chip etc that will allow me to communicate with the propeller for the purposes of updating or checking the status of the device.
Paul
But, if this is a commercial application, I suggest you to go with a serial port and interface that with an external gsm module (you will find many of them available from many vendors for several temperature ranges and IP grade protection). This will leave also the opportunity to use gsm/umts/radio/classic56k modems and, why not, a virtual tcp/ip serial port on internet/intranet network.
Paul
