Level shifting 0-5V to +-5V
What's the best way of doing this? We have a piece of equipment that needs a +-5V signal, but our source supplies 0-5V. A source of +-5V would cost us a couple hundred dollars more, so we would like to use a conversion if possible. Preferably something I might be able to build using logic or something not too complex...
Rafael
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Rafael
You can't win.
· -- Carl, nn5i@arrl.net
(www.intersil.com/data/fn/fn3072.pdf) that can take an input of 5-10V and produce an output of -5V. Typically,
for an analog output, you'll have an opamp powered by +5V and -5V whose output voltage can swing between those two voltages.
The opamp can be biased to use 0-5V as its control voltage for the full range. For a digital +5V / -5V output, you could use a
transistor for switching like in the RS232 to TTL adapters that Parallax uses with the Stamps for programming. You could also
use something like a MAX3232 which includes the voltage inverter and the line driver all in one package. The output
voltage tends to vary with load, up to maybe +6V/-6V, but this could be reduced by adding some capacitive/resistive loading.
Rafael
You can't win.
The MAX865 contains just the charge pump/inverter circuitry from the MAX232, so it will deliver an approximate +/-10V supply for your op amp. I would recommend using this wider supply range, so your opamp has enough headroom to drive a load. (There are so-called "rail-to-rail" op amps available that would work with a +/5V supply, but their load-driving capabilities at the extremes of their output range are almost nil.) When picking an op amp, be sure to pick one that can handle a capacitive load if you're driving a cable with it. I've had good success with an OP113 in apps like this.
Thanks alot!!
Rafael
You can't win.
Post Edited (FlyingFishFinger) : 2/6/2009 7:23:09 PM GMT
