I like mouser because they have a very nice search function that allows you to narrow in your parts quickly. There're also pretty fast when everything is in stock.
I actually prefer digikey's parametric search function better than mouser's, but mouser typcally has cheaper prices and they don't have a under $20 purchase surcharge. Newark has a good selection on some specialty ICs (such as·single gate logic chips and FRAM). Frequently when I don't know what exact chip I want (I know the parameters, but not a manufacturer or part #), I use digikey to find the desired chip, then use www.findchips.com to locate which supplier has the best price.
For a Canadian PCB fab, try www.apcircuits.com. They're located in Calgary. I used to use them all the time before switching to the more local (for me) Advanced Circuits in Colorado. For volume PCB production in Canada, I've had good luck with www.lazer-tech.com.
Post Edited (Phil Pilgrim (PhiPi)) : 1/27/2009 2:58:51 AM GMT
Just checked out www.apcircuits.com They are very reasonable for small boards 8x1 only $34 each. Calgary is really convenient since I live here.
In the past I have used 4pcb.com they are fast and great. Also offer $33 boards at fairly large size. The only down side is shipping to Canada comes to $50+tax and handling fees. If you use them tell them Matthew Cornelisse of Visible Photo referred you.
jameco.com
alliedelectronics.com
futureelectronics.com
uk.farnell.com/jsp/home/homepage.jsp
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
PS Newark and Digi-Key have Canadian locations.
Paul Baker
Post Edited (Paul Baker) : 1/27/2009 12:00:36 AM GMT
· -- Carl, nn5i@arrl.net
