Noritake VFD Display Timing
Hi, I am using the Noritke 112x16 Display avaliable at Parallax to debug output and also when my robot is fully ready to display information such as temperature (using a ds1620), time (ds1302 on ppdb), and eventually speed of the robot as well.· what i'm wondering is if there is a way to buffer the data going to the display and send it all at the same time, or to tell the chip when i'm done sending data and display it all at once, i'm getting a mean flicker every time it redraws.· I'm only redrawing it every second since thats the update time on the temp chip and the clock (no need to display milliseconds since the precision isn't that high on the clock).· Does anybody know a way to do this, or if the vfd has a backbuffer type redraw?· Thanks in advance!· Just for kicks i'm gonna submit my code on here, seeing as this is my first spin experience, i'm sure the code is awful, so please don't laugh.· [noparse]:)[/noparse]·
Russ
Russ
When you redraw are you clearing the screen? You don’t want to clear the screen each time you update or this will cause flicker. If you can get away with it, set up your draw routines to just home the cursor and redraw this way. This also happens on LCD displays. Take care.
Chris Savage
Parallax Engineering
There is nothing wrong with the look of your code! In fact, it's even heavily commented. Nice work!
I suspect (as usual) that Chris is right on the track with the flicker issue. [noparse]:)[/noparse]
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Chris Savage
chris: i was indeed clearing the screen every redraw, i was under the assumption that this is the easiest way to get back to the origin.· is there any code examples floating around that demonstrate positioning with this vfd?· i briefly looked at the obex, but didn't see anything about the vfd, lots about other serial lcd's but they look like they are operating differently.· I'd love some code examples i could look at in spin that show off the capability of this device.· thanks a lot for the help!·
...Like I said.. "as usual"... <SMIRK> Good call.
OBC
Typically on an LCD, and so on the VFD too, I would redraw the screen by repositioning the cursor at the home position. Most displays have a HOME command and the Noritake Display is no exception. Instead of using the command $0C, use $0B. This will position the cursor in the top-left position of the current window (the screen, if you haven’t defined any windows). You can do this at high speed without display flicker. The only thing is if you’re drawing less data you have to remember to space over the old data. For example, if you printed the following line:
And later you redraw and the value changes:
Then you could have the following display if you didn’t account for the difference in characters. It is for this reason I will often use fixed positions and pad small values. I hope this helps. Take care.
Chris Savage
Russ
p.s. you mentioned windows.· I suppose your talking about what i saw on noritakes website about having seperate regions of the screen displaying different things.· is there a place i can go for documentation on that feature?· it would be very handy for the project i'm working on.· Thanks again!
russ
That is what I was going to suggest. Unfortunately we are not allowed to publish the full specification. It must be requested directly from Noritake. We can only list the brief. That is why the App Note tried to cover as many commands as I could fit into it.
I’m not sure it provides much more information than the AppNote, but Jon Williams did write a Nuts & Volts article on the display. You can find it at the following link. It’s the one called, “Going with the Glow”. I hope this helps. Take care.
http://www.parallax.com/Resources/NutsVoltsColumns/NutsVoltsVolume7/tabid/450/Default.aspx
Chris Savage
Russ
