Need help on RFID Card Reader Serial 28140 please.
Hi,
I am currently doing a project, it include a Microchip Explore 16 mcu board, a Parallax reader (28140) and interface with pc (VB6).·I have a few qustions:
1) Does this sound like doable?
2) If so, how can i connect the reader on the board? i did some research on the reader, it said i only need to connect 1 wire to the board. Most of the info i found is connected to a LCD so i have no idea where should i connect the wire on the board.
3) The main purpose is to keep track of the card that swiped, so basically after i swiped 3-4 cards, i check it on VB to see which card, name, time, can i do that?
Please help me out [noparse]:)[/noparse]
- Stephen
Pin 1 VCC +5V DC input.
Pin 2 /ENABLE Bring this pin LOW to enable the RFID reader and activate the antenna.
Pin 3 Serial Output,·TTL-level interface, 2400bps, 8 data bits, no parity, 1 stop bit.
Pin 4 GND
You will need to connect the ( +5V DC input and ground) on the card reader to the (+5V DC and ground) on your target board; Pin 2 must be taken LOW to enable the serial output on Pin 3. Since the serial output is TTL, you can connect it directly to an input pin on the microcontroller. The manual provides details on decoding the output stream.
Craig
(' {$STAMP BS2} ' {$PBASIC 2.5} ' File....... RFID.BS2 ' Purpose.... RFID Tag Reader / Simple Security System ' Author..... (c) Parallax, Inc. -- All Rights Reserved ' E-mail..... [url=mailto:support@parallax.com]support@parallax.com[/url] ' Started.... ' Updated.... 07 FEB 2005 ' ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' Reads tags from a Parallax RFID reader and compares to known tags (stored ' in EEPROM table). If tag is found, the program will disable a lock. ' -----[noparse][[/noparse] Revision History ]------------------------------------------------ ' NOTE: Install LCD TxPin on pin 0 ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Enable PIN 4 ' low = reader on RX PIN 5 ' serial from reader Spkr PIN 2 ' speaker output Latch PIN 3 ' Lock or Latch control Green LED Alarm PIN 6 ' Alarm control RED LED ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- #SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 TMidi CON 12 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 TMidi CON 60 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 TMidi CON 108 T38K4 CON 84 #ENDSELECT '------------------------[noparse][[/noparse] LCD Constants ]--------------------------------- LcdBaud CON T19K2 LcdBkSpc CON $08 ' move cursor left LcdRt CON $09 ' move cursor right LcdLF CON $0A ' move cursor down 1 line LcdCls CON $0C ' clear LCD (use PAUSE 5 after) LcdCR CON $0D ' move pos 0 of next line LcdBLon CON $11 ' backlight on LcdBLoff CON $12 ' backlight off LcdOff CON $15 ' LCD off LcdOn1 CON $16 ' LCD on; cursor off, blink off LcdOn2 CON $17 ' LCD on; cursor off, blink on LcdOn3 CON $18 ' LCD on; cursor on, blink off LcdOn4 CON $19 ' LCD on; cursor on, blink on LcdLine1 CON $80 ' move to line 1, column 0 LcdLine2 CON $94 ' move to line 2, column 0 LcdCC0 CON $F8 ' define custom char 0 LcdCC1 CON $F9 ' define custom char 1 LcdCC2 CON $FA ' define custom char 2 LcdCC3 CON $FB ' define custom char 3 LcdCC4 CON $FC ' define custom char 4 LcdCC5 CON $FD ' define custom char 5 LcdCC6 CON $FE ' define custom char 6 LcdCC7 CON $FF ' define custom char 7 TxPin CON 0 Baud19200 CON 32 '-------------------[noparse][[/noparse] Stamp Select ]-------------------------------------- #SELECT $STAMP #CASE BS2, BS2E TmAdj CON $100 ' x 1.0 (time adjust) FrAdj CON $1500 ' x 1.0 (freq adjust) #CASE BS2SX TmAdj CON $280 ' x 2.5 FrAdj CON $066 ' x 0.4 #CASE BS2P mAdj CON $3C5 ' x 3.77 FrAdj CON $044 ' x 0.265 #CASE BS2PE TmAdj CON $100 ' x 1.0 FrAdj CON $0AA ' x 0.665 #CASE BS2PX TmAdj CON $607 ' x 6.03 FrAdj CON $2A ' x 0.166 #ENDSELECT ' ------------------------------[noparse][[/noparse] CONSTANTS 2 ]------------------------------- LastTag CON 3 SevenBit CON $2000 Inverted CON $4000 Open CON $8000 Baud CON T2400 ' ---------------------------------------[noparse][[/noparse] ]-------------------------------- #DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have SPRAM? ' ------------------------------[noparse][[/noparse] Variables ]------------------------------- buf VAR Byte(10) ' RFID bytes buffer tagNum VAR Nib ' from EEPROM table idx VAR Byte ' tag byte index char VAR Byte ' character from table ' ----------------------------[noparse][[/noparse] DATA DIRECTIVES ]-------------------------- Tag1 DATA "0F03038AA2" ' valid tags Tag2 DATA "0F030299A1" ' valid tags Tag3 DATA "0415AFD883" ' valid tags Name0 DATA "Unauthorized stop immediatly", CR, 0 Name1 DATA "Randy you may proceed", CR, 0 Name2 DATA "Stephanie you may proceed", CR, 0 Name3 DATA "WORLD TAG", CR, 0 ' -----------------------------[noparse][[/noparse] Initialization ]--------------------------- Reset: SEROUT TxPin, Baud19200, [noparse][[/noparse]12] PAUSE 50 HIGH Enable ' turn of RFID reader LOW Latch LOW Alarm ' lock the door! ' -----------------------------[noparse][[/noparse] Program Code ]----------------------------- Main: GOSUB Write_tagnum SEROUT TxPin, Baud19200, [noparse][[/noparse]Lcdbloff] SEROUT TxPin, Baud19200, [noparse][[/noparse]12] PAUSE 50 SEROUT TxPin, Baud19200, [noparse][[/noparse] "Hello, Please scan your RFID"] LOW Enable ' activate the reader SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID HIGH Enable ' --------------------------[noparse][[/noparse] Subroutines Check_List ]----------------------- Check_List: FOR tagNum = 1 TO LastTag ' scan through known tags FOR idx = 0 TO 9 ' scan bytes in tag READ (tagNum - 1 * 10 + idx), char ' get tag data from table IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table NEXT GOTO Tag_Found ' all bytes match! ' --------------------------[noparse][[/noparse] Subroutines Bad_Char ]------------------------ Bad_Char: ' try next tag NEXT ' --------------------------[noparse][[/noparse] Subroutines Bad_Tag ]------------------------ Bad_Tag: tagNum = 0 HIGH Alarm GOSUB Show_Name ' print message FREQOUT Spkr, 1000 */ TmAdj, 115 */ FrAdj ' groan PAUSE 1000 LOW Alarm GOTO Main ' --------------------------[noparse][[/noparse] Subroutines Tag_Found ]------------------------ Tag_Found: DEBUG CLS DEBUG HOME GOSUB Show_Name ' print name DEBUG " " , tagNum ' print tag number HIGH Latch ' remove latch FREQOUT Spkr, 2000 */ TmAdj, 880 */ FrAdj ' beep LOW Latch ' restore latch GOTO Main END ' ----------------------[noparse][[/noparse] Subroutines Show_Name ]----------------------- Show_Name: ' Prints name associated with RFID tag LOOKUP tagNum, [noparse][[/noparse]Name0, Name1, Name2, Name3], idx ' point to first character HIGH TxPin ' Set pin high to be a serial port'PAUSE 100 SEROUT TxPin, Baud19200, [noparse][[/noparse]12] PAUSE 50 SEROUT TxPin, Baud19200, [noparse][[/noparse]LcdBLon] PAUSE 50 SEROUT TxPin, Baud19200, [noparse][[/noparse]"RFID Detected"] PAUSE 750 SEROUT TxPin, Baud19200, [noparse][[/noparse]12] PAUSE 50 SEROUT TxPin, Baud19200, [noparse][[/noparse]"Scanning ...."] PAUSE 500 SEROUT TxPin, Baud19200, [noparse][[/noparse]12] DO SEROUT TxPin, Baud19200, [noparse][[/noparse]LcdBLon] READ idx, char ' read character from name IF (char = 0) THEN EXIT ' if 0, we're done SEROUT TxPin, Baud19200, [noparse][[/noparse]char] SEROUT TxPin, Baud19200, [noparse][[/noparse]Lcdbloff] DEBUG char ' otherwise print it idx = idx + 1 LOOP ' point to next character RETURN▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Chris Savage
Parallax Engineering
