Shoving 3 pin single row header (long) into a Conductive Foam for a Pressure se — Parallax Forums
EzsynnEzsynn Posts: 119
edited 2009-02-07 10:49 in General Discussion
Would That Work?
BWIN ON DA POWAH WIFIN U!!!
Post Edited (Ezsynn) : 2/5/2009 10:20:07 AM GMT
    edited 2009-02-05 14:37
    You're not giving much in the way of information. If you want a useful answer, you need a clear question.
    Would what work? "Shoving 3 pin single row header (long) ... sensor"?
    You can shove something into a block of Jello. Whether that will do something useful is another question. What are you trying to accomplish?
    Depending on the header pins and the conductive foam and how you're shoving it, you can break or bend the pins, tear the foam, or successfully get the pins into the foam without damage. Depending on how you hold the thing, you might damage the sensor or not.
  • ZootZoot Posts: 2,227
    edited 2009-02-05 14:58
    Ezsynn -- if you are thinking about the conductive foam pressure sensor hack (using "anti-static" IC foam), generally that technique involves putting two very thin metal plates (or even aluminum foil) on either side of the foam. Wires are attached to the metal. Then the whole thing acts like a variable resistor when squeezed/pressed.
    Two issues you have to take into account:
    - the amount of resistance changed can be small; you need to be able to measure it reasonably accurately (RCTIME with solid components)
    - the foam will not return to it's original state completely, so your code will need to take that into account and essentially look for rapid "change" in resistance as indicative of pressure, not absolute values, i.e.
    pseudocode:
    do
    -> measure resistance
    new "steady" state = resistance
    wait
    if ( ABS (new - old) / old ) > .25  then  ' basically a change of more than 25% from whatever it was is "pressure"
        under pressure
    endif
    ' or
    pressure =  ( ABS (new - old) / old ) * 100 ' pressure "value" 0-100
    loop
    edited 2009-02-05 16:44
    Ezsynn,
    Here is a thread that may help you.
  • EzsynnEzsynn Posts: 119
    edited 2009-02-07 03:30
    Phil Pilgrim (PhiPi) said...
    Ezsynn,
    I know that but Would the title of this thread work?
    edited 2009-02-07 03:32
    I have no idea. Why don't you try it and see for yourself?
    edited 2009-02-07 07:07
    Ezsynn,
    Try it and see. Report back with your results.
    If your talking about the action of inserting the 3 pin single row header into the foam to cause a change in resistance, it will probably be a very small change due to series-parallel resistor effects within the foam at the point of insertion. See attached image. The resistance change will be most noticeable near the peripheral but quickly decay as you move inward.
    If your talking about compressing the foam near the area of where the 3 pin single row header is inserted, it might give more resistive range, but the mechanical wear and tear of the foam compressing around the 3 pin single row header will eventually destroy the foam.
    Beau Schwabe
    IC Layout Engineer
    239 x 343 - 45K
    Beau Schwabe (Parallax) said...
    Ezsynn,
    Ah I get you. But still the Idea stands.
