Using Relays with the propeller
I am in the initial stages of the design to use a propeller to control a gas valve and a pump. I have sourced the following:
Still deciding on which one also open for a better solution if someone has one
www.crouzet-usa.com/catalog/_caso.shtml
www.crouzet-usa.com/catalog/_ga8.shtml
both of these relays will work on 3 volts so I should be good there. Here is where I get lost. I am still learning in this area. Do I need a resistor or something here to protect the propeller? should I put a resistor between the input pins?
I also noticed that the controller board that parallax sells uses mosfet on the high voltage lines, does that accomplish the same thing ?
I will also be using the thermocouple interfaces available from the store.
I am currently using 2 of these to get the job done, however they are limited in scope to 1 step. I would like to start by simply replacing them with my propeller project, then enhance it after the basics are complete.
Does anyone have any input on whether I should go for a prototype board or a PE Kit to start with?
Thanks in advance
Greg
Thanks in advance
Greg
As for relays you should always put a diode in reverse across the coil terminals to protect circuitry attached to the relay. Most likely the propeller can not provide enough current to directly activate the relays so you should use a transistor or mosfet to act as a switch providing direct current from the power rail but you can check the specs of the relay to see.
Thanks for pointing out the current maximums, but I believe the manual says not over 100mA for a group of pins. The obvious question then, which I have not seen answered in the book, is what are the groupings of the pins.
Thanks so much for your help. They should give you a propeller avatar.
Doug
With a max across all pins not exceeding 300mA.
Didn't see anything about groups of pins.
