What did you do before micro-controllers?
Hi all,
I have read though many posts and topics, there is one very interesting thread that discussed old school hackers. I was wondering what everyone else did before Basic Stamp came along and made our lives so much easier? I mean, if you needed a program controller what did you do?
I have this photo of a 'Program controller' that I made for a machine I built back in the day.
Pressing the buttons would make different patterns on the lights. I remember it had a bunch of timers in it like the one in your picture.
I wish I had that thing now. But I'm sure I took it apart to see how it worked.
That was MANY years ago. My dad pasted away in 1979, but your post brought back one great memory. Thanks for posting it.
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
Ever seen the reeled perforated paper strips that loop past all of its pneumatic doo-hickeys?
Somebody once described to me a circa 1968ish space mission that was to send a vehicle as close to the sun as possible. Because electronics couldn't take the heat for long, it was to be flown completely by fluidic logic. I was told that they had machined an incredible number of little hydraulic valves that would work like fluidic transistors and the whole thing would work via logic circuits made for high temperature fluids. I always wanted to ask how the communication system worked - smoke signals maybe???
Post Edited (ElectricAye) : 2/5/2009 3:19:23 AM GMT
The cam assembly in the photo actuated micro-switches, which in turn powered relays, which then operated solenoid valves to actuate pneumatic cylinders.
Man, the hoops one had to jump through just to make a reliable system.
Mike2545
The electrical storm of noise that is generated by the compressors, relays, switches, & motors that are an integral part of the design, just make those chips go nutty half the time.
Mike2545
Glancing at that picture you posted from the picture icon, reminded me of a "mechanical cash register/adding machine" I took apart as a kid ... anyone ever take apart one of those? LOTS of ingenuity there.
Before micro-controllers? - I would use discrete logic and FPGA's ... lots of analog circuitry design.
Beau Schwabe
IC Layout Engineer
Marvin Minsky, Daniel Dennett, are you listening to this?
Of course, designing building and installing such complex control boards had major drawbacks. Any changes/upgrades had to be made with a soldering iron instead of a few lines of code.
Mike2545
I/O does not need IO port chips (8255, 6821, etc.). You could use 74x244s for input, and 74x373s for output. (Or was it a '377?)
--Rich
I guess I chose the Stamp because I learned Basic when the first generation of personal computer came out.
Mike2545
Chris Savage
Parallax Engineering
Mike2545
I made a similar electro mechanical controller for a water softener that had been hit by lighting.I found the paper work from Callaghan on the softener, with a schematic. I robed the timer parts out of a RainBird irrigation controller. This was not a one or two evening project like we have now with the micros ($STAMPs). It took Me a while to make it all work.
It would have been Alot easier with a $stamp.
On a side note; If it was not for Forest M. Mims III and RadioShack, That project would have never happened, And I wouldn't be here on this post reply.
Like Mr.Savage, I to had that 150 in 1 Lab, and all the Engineers note books From Mr Mims and RadioShack. I learned so much from these labs and notes!
I want to thank RadioShack for their effort's back in the day!!!!, And hopefully Days to come.
_______________$WMc%____________________
RadioShack has Parallax senors in stores all across the USA!
The Truth is out there············································ BoogerWoods, FL. USA
Post Edited ($WMc%) : 2/6/2009 3:03:22 AM GMT
That drumswitch pic really took me back to the '70's when I had to use ones just like that to control the water treatment system in a large power plant. And, the throttle in an electric car I built in the early '80's used one too.
It strikes me funny that on Monday I'll be teaching a PLC course on a system that was introduced in late 2008. One of the commands which has been reworked and updated is the "drum" instruction which makes it easy to simulate that old-style electro-mechanical switch.
A real case of what's old is new again.
Cheers,
Tom Sisk
http://www.siskconsult.com
In that light, I found this on flickr:
http://www.flickr.com/photos/blazerman/2371910888/
Ah, those were the days.
DJ
I've always been fascinated by relay-logic, and it would be cool to build a simple add/subtract/multiply/divide calculator using relays.· Every button-ush would cause a clattering of relays.· That reminds me of the old mechanical calculators I used years ago.· Multiplies and divides were very noisy operations as the adding machine would churn through each decimal place.
Dave
I think I understood you, I just never had good performance/reliability out of the 74xx line. Those chips were power hungry and it seemed to me that electrical noise made some of them operate erratically. Oh I used them because that was what I had.
By the way I pulled my 1974 copy of the Signetics Data book off the bookcase and your memory is pretty good the '172 is an eight word two bit register.
Mike2545
I also built a Jacob's Ladder with a Model T Spark Coil.
I shocked myself so many times with that thing!
I still have a 300 in 1 Electronics Lab.
By the way, I was at Radio Shack the other day and they have Mim's Getting Started in Electronics again!
Whit+
Post Edited (Whit) : 2/7/2009 3:06:04 AM GMT
That HP power supply really surprised me though. It would put out 5V at 50amps day after day, and at about 55 amps would go into current limiting mode. Take the short off and the supply went back to 5 volts as if nothing had happened. I was impressed.
www.break.com/index/marble-based-calculator.html
No Stamp involved...just gravity.
Mike2545
