A faster stamp can definitely slow down to talk to a slower stamp. Take a look at the SEROUT/SERIN sections in the Syntax and Reference Guide for information on how to do this. Basically, it involves changing a constant. You'll probably want to use 396, but check to make sure.
Those baud rates you listed are only for the programming and DEBUG. For any SERIN/SEROUT communication you must specify the baud rate with the correct parameter in your statement. The list of valid baud ranges for each BASSIC Stamp model can be found in the Help File or in the BASIC Stamp manual. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Engineering
Chris Savage
