Nixie tube / transistor help
Can anyone share any sort of advice and/or schematics of how to safely connect a BS2 to a single Nixie tube? I cannot seem to get the transistor to work properly.
I have a BS2, MPS A42 or MPS A92 (not sure which one to use) and a power supply to get my 180v for the IN-8 Nixie tube.
Namely what I cannot figure out is how to close the circuit with the BS2 and transistor. i.e. If I connect the output from the BS2 to the Base of the transistor, where does the ground from the BS2 go?
I am still a huge newbie so please 'speak slowly'.
Thanks in advance
Ben
Thanks in advance
Ben
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
As for the ground, do I need a diode in there somewhere to protect the BS2? If so, any suggestions as to which one or where it should go?
Thanks again!
Ben
The reverse connected diode you mentioned is for inductive loads like relays, motors, and solenoids. You don't need it in this case.
Jonathan
· -- Carl, nn5i@arrl.net
PS Where did you get the Nixies? E-Bay?
