Weighing Scales
Has anyone done a project to build an electronic weighing scales ?
I want to be able to weigh up to 600kg approx.
Is this possible ?
Is this possible ?
I should have perhaps put some things in perstective.
I have an existing setup that connects three load cells to a common box.
The electeonics in the box look complicated.
You can flick a switch to read the data from each load cell.
Having select a load cell you can also push a button to zeroise the 'no load' on the cell.
The equipment is difficult to operate (sensitive to moisture etc.)
I will look at the load cell(s) and try to determine exactly what they are.
My thinking is that I might be able to replace electronic circuitry with a simpler configuration.
What further information can I supply ?
Am I on the right track ?
Amazon.com/Digital Scale
Of all the things I have lost...
I miss my mind the most.
Post Edited (Tex4u) : 2/3/2009 10:07:01 PM GMT
The typical load cell system uses a Wheatstone bridge - see attached picture - to calculate the resistance of the strain gauge. The first three resistors (R1-R3) are high precision resistors, usually 1% or less with a low temperature coefficient.
The fourth resistor (R4) represents the·strain gauge.
You can measure the voltage with an analog to digital converter and calculate the resistance of the strain gauge, and the resultant weight, with some simple math. Parallax has an application note using a serial interface to the Linear Technology 12 bit, dual channel·LT1298.
I can post more information if desired.
Craig
I used a similar kitchen·scale as the link posted by Tex4u for the rain gage on my weather station. Depending on the characteristics of the particular load cell, you may find the output is too low for rctime or the LT1289 to give an accurate or precise reading. I ended up using an AD7705 to read the output of the cell. It has a built in amplifier as well as the ADC. This chip has some built in calibration capabilities - in my programming, I do an automatic calibration and·zero adjustment during startup.
Do you have any information on the three cells you already have?
Search the forum for messages from Mohamed Refky, who has posted quite a bit on his weigh scale design. For example,
http://forums.parallax.com/showthread.php?p=540915
or in the egroups archive:
forums.parallax.com/forums/default.aspx?f=19
Generally you need a 16 bit or better ADC for load cells.
Tracy Allen
www.emesystems.com
http://www.nakka-rocketry.net/strainlc.html
cheers, David
http://forums.parallax.com/showthread.php?p=616474
http://forums.parallax.com/showthread.php?p=718875
Three load cells are connected in parallel directly to the AD7730
