qfn center pad in eagle?
I'm an eagle rookie, so I am just looking at things and trying to understand what I am seeing.· When I look at the details for the qfn version, the center pad seems not connected to anything. Neither ground nor vdd.
The library is called Parallax_Propeller. It has all three versions.
If it's not connected, can I split it with another trace?
Is the qfn bottom just a thermal patch unconnected to the chip or is it part of the chip's·ground?
Post Edited (Fred Hawkins) : 2/2/2009 3:05:48 AM GMT
I would like to use this package myself but have no expierence with them. BGA self aligns with vias bellow but this i think may be difficult for hand work.
Paul Baker
Post Edited (Paul Baker) : 2/2/2009 8:37:21 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
www.fd.com.my
www.mercedes.com.my
Leon
I could use a heat gun and my experience to solder the IC using solder paste. Realistically I send it to a PCB assembly house and typically they let me use the equipment for free. Its nice to learn how the PCB board assembly works so that when I design I can use what I learned from an assemblers point of view.
maybe you can call a local PCB assembly shop and ask for a tour and or what it would cost to make you're prototype.
Also I ground the pads on the propeller QFN.
