Timing out a serial connection? — Parallax Forums
DiverBobDiverBob Posts: 1,125
edited 2009-02-02 22:08 in Propeller 1
I haven't found any posts with this particular problem...
I have a serial connection as part of my initialization routine where the connection is initialized, 2 characters are transmitted and then I wait for a response. But it is possible that there may not be any response - using the standard .rx command in FullDuplexSerialPlus.spin the program then hangs at this point until I cut the power. Is there a method for timing out the connection if there is no response after a reasonable amount of time so the rest of the app can run?
Bob Sweeney
  • TreeLabTreeLab Posts: 138
    edited 2009-02-01 16:20
    There is a rxcheck routine that returns immediately; if the result is -1, there was no character ready, otherwise it brings back the first received character (ie the first in the receive buffer). You can put a call to rxcheck in a timing loop to see if a coherent response is obtained in a specific time.
    There is an rxtime routine as well that does this for a specific delay, but this blocks the execution cog from doing other things while in the polling loop.
    Cheers!
    Paul Rowntree
    Post Edited (TreeLab) : 2/1/2009 4:25:40 PM GMT
  • DiverBobDiverBob Posts: 1,125
    edited 2009-02-01 16:31
    I hadn't been online for about 3 days, I posted my issue, then started reading all the current posts and wouldn't you know it, someone else with a simular issue and solution! Teach me to finish reading before posting!
    Thanks for the info, I had looked over the rxcheck command but I guess it didn't sink in that it only checks the rx buffer for input. I can put the rxcheck in a 1 or 2 second timing loop and if the buffer is still empty I can push the app into 'test mode' and run fake data instead of waiting forever for serial data!
    Thanks again!
    Bob Sweeney
    edited 2009-02-01 20:32
    Hello Bob,
    take a look into the RxTime-method inside the FullDuplexSerial-object
    best regards
    Stefan
    edited 2009-02-01 20:47
    I did look at the rxtime routine but for some reason it didn't seem to have a time-out. Can you explain how it is supposed to work?
    Bob
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2009-02-01 20:59
    a:=serial.rxtime(100)
    That will try for 100ms and if no response returns -1
    edited 2009-02-01 21:32
    Hello Bob,
    you should trust a little more in the comments of the code of FullDuplexSerial
    PUB rxtime(ms) : rxbyte | t
    '' Wait ms milliseconds for a byte to be received
    '' returns -1 if no byte received, $00..$FF if byte
      t := cnt
      repeat until (rxbyte := rxcheck) => 0 or (cnt - t) / (clkfreq / 1000) > ms
      t := cnt
    stores a snapshot of the systemcounter in variable t
    calculates the amount of time that has been gone since the snapshot
    and as this time is MORE than the value of "ms" the waiting inside the repeat until-loop ends
      repeat until "byte received or (cnt - t) / (clkfreq / 1000) > ms
    here is a democode showing how it works
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    OBJ
      Debug : "FullDuplexSerial" 'serial connection to PC
    PUB Main | Char
      Debug.Start(31,30,0,115200) 'start(rxpin, txpin, mode, baudrate) :
      ''       okay '"rx" and "tx" viewed from Propeller-Chip Propeller-Chip-PIN-Tx ----> PC
      Debug.Str(string("START",13))
      Debug.Tx(13)
      repeat
        Debug.Str(string("Wait for 5 seconds to receive a byte...",13))
        Char := Debug.rxtime(5000)
        if Char == -1
          Debug.Str(string("nothing received until Timeout",13))
        else
          Debug.Str(string("received byte:"))
          Debug.Tx(Char)
          Debug.Tx(13)
        Debug.Tx(13)
        Debug.Tx(13)
        Debug.Tx(13)
    best regards
    Stefan
    Maybe I should add a signature like that
    "there are two ways of learning programming
    1.) a slow one: ask EVERYTHING on the forum three words short
    2.) a quick one: try something yourselve - ask the forum 10 sentences long -attaching your code - go adding debugoutput to your code while waiting for the forum-answers
    For some reason when I read the comments it just didn't 'click' as to what was happening. Thank you to everyone who answered.
    I have been a professional database and applications programmer for well over 20 years, I have studied numerous languages and am proficient in several, but I will be the first to admit that I am not perfect in each language I use. Since spin is only a hobby and I usually am using it when I'm tired in the evenings after a full day of my paid job, sometimes I just don't 'get it' right away. Once I read the posts and checked the serial code I saw what I needed then. Sometimes a little help goes a long way.
    So forgive me if I am a little slow sometimes, I think this forum has been a great place to learn no matter what your level of competance. Please have some patience with those who aren't at your level yet.
    Bob Sweeney
