Drive an RGB Analog monitor
Has anyone tried to drive an RGB Analog monitor with the Propeller? These monitors were common in the mid-80's and could do 640 x 200 (Non-interlaced) or 640 x 400 (Interlaced). These monitors were typically connected to Atari ST and Amiga computers. I have a nice Sony 20 inch XBR RGB Analog monitor and think it would make a good match with a Propeller displaying 80 column ASCII art http://forums.parallax.com/showthread.php?p=724964
Can you post your composite driver to object exchange, or attach it here for the PASM impared?
Doug
http://forums.parallax.com/forums/default.aspx?f=25&m=278137
If you want more information on it, check out these links:
http://www.gamesx.com/avpinouts/psxav.htm
http://obex.parallax.com/objects/338/
http://forums.benheck.com/viewtopic.php?t=469&postdays=0&postorder=asc&start=0
http://www.bit-tech.net/modding/2004/07/07/psone_lcd/1
http://www.extremetech.com/article2/0,1697,1765353,00.asp
http://www.applefritter.com/node/10929
http://www.gearlive.com/index.php/news/article/how_to_psone_lcd_your_computer_05110831/
http://www.mp3car.com/vbulletin/lcd-display/14066-playstation-lcd-hack-works.html
http://freespace.virgin.net/john.laura/Hacking a PSOne LCD.htm
As you can see it is a very versitile little monitor. With the proper mods, it will take VGA, Composite, Svideo inputs. Very nice.
