LED Matrix Drivers, differences?
As far as driving an LED matrix, It seems there's more than one way to skin the cat. From what I can tell the most popular chips are either the max7219 or using a shift register like the 74HC595. Can someone tell me why you would want to use one over the other?
- setting current for all connected LEDs with a single resistor
- scanning/matrixing capabilities for driving many LEDs at once from fewer pins (i.e. 16 pins to drive 64 LEDs)
- shutdown/startup/sleep
- PWM brightness (either for all LEDs as a set like the 7219 or per LED)
- depending on model, decoding of HEX characters to 7-segment displays
- etc.
Also, '595s differ by model in terms of what they can drive at output. Some will drive 20-50ma on each pin; some only 6ma (less than a Stamp pin). LED drivers are usually only limited in terms of total current through the chip's Vdd and Vss pins, and is often quite high.
This doesn't mean that using a '595 isn't totally appropriate, for say only 8 leds where you don't mind resistors for each LED and you don't want to keep refreshing the output.
The XMOS chips will do PWM on each LED in very large arrays:
www.xmos.com
They are probably overkill for your application, though.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
