Anyone know a good source for cheap analog gauges?
I'm looking for some old analog gauges. The type that are circular with a needle that moves depending on how much current you run through the contacts. Does anyone know where to find them?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
www.meterdistributor.com/Triplett/Triplett%20Panel%20Meters.html
I have not ordered from them before but they have a huge selection.
Mike2545
I have 5 or 6 meters. about 4"H x 6"wide.They are working pulls from a retrofit at work. I hated to throw them out, So I held on to them.If Your intrestied I can send them to You. This way I know they went to some good use. You can drop Me a PM with the mailing info if You like.
_____________$WMc%____________
The Truth is out there············································ BoogerWoods, FL. USA
