How to extract time?
Hi,
I am currently using a Boe-Bot with·BS2sx microcontroller. I need to calculate the point to point·velocity using distance/time.
I am able to calculate the distance using a localizer. Due to the localizer, the encoders are not used.
However, I am facing a problem with the time information.
Usually, there is·an internal clock in a·microcontroller.
Is there any relevant function or command to extract the time taken·for the Boe-Bot to travel from one point to another?
Did you build the localizer or buy it? I'd like to have a localizer.
I'm using the Propeller on my robot. For the Propeller you calculate time with the System Counter register named cnt.
PG
WGX Can you tell me what you have achieved so far?
