waitpne/waitpeq issue
this is probably pretty easy but i havent found a solution yet: I'm measuring a frequency by sampling, just like the object that you find in the obex.
the method is pretty simple and uses WAITPNE to get the positive edge of the flank and WAITPEQ to get the negative. now if there is NO change in voltage/no signal on the pin it will simply block. What would be a simply way of getting a timeout into this assembler piece?
detector
:mainloop MOV :t1, par ' get buffer pointer
MOV :lock, :t1 ' set lock pointer
ADD :t1, #4 ' offset for lock
WRLONG :one, :lock ' assert waiting state
:wait RDLONG :t2, :lock
TJNZ :t2, #:wait ' wait for clear
RDLONG [img]http://forums.parallax.com/images/smilies/tongue.gif[/img]in, :t1 ' set pin mask
ADD :t1, #4 ' offset for pin mask
MOV :ctr, #SAMPLESIZE ' set counter
:loop WAITPNE :zero, [img]http://forums.parallax.com/images/smilies/tongue.gif[/img]in ' wait for pos edge
WAITPEQ :zero, [img]http://forums.parallax.com/images/smilies/tongue.gif[/img]in ' wait for neg edge (pulse)
MOV :t2, cnt ' capture time
WRLONG :t2, :t1
ADD :t1, #4 ' next buffer position
DJNZ :ctr, #:loop ' capture loop
JMP #:mainloop ' main loop
