Formatted Numeric Output (SX/B 2.0)
JonnyMac
For those that have struggled with sending numbers to terminals and serial displays this demo should help. It demonstrates the use of local variables, the new STR and HEXSTR instructions, and using libraries -- the result is clean numeric output to a serial device.
Thanks for the libraries.
As the number of libraries is still small, let me make a suggestion.
You enclose the library code in '{$ifused subname}-'{$endif} blocks
which is good. You have grouped related subroutines in a single library file which is
also good.
Something that may become a problem when the number of libraries grows·is the
limited number of SUB declaration that sxb supports, the limit is 128 because
all declared subs require 2 bytes in the lower half of codepage 0.
Even if you only need TX_STR, the other subroutines still occupy entries
in the subroutine jumptable. If you need to include more libraries as the program grows,
this will quickly fill the jumptable.
The way I resolve this is by using the '{$USES subname} directive
that I place at the top of the·main program file, before loading the xxx_DEF.SXB files.
eg. '{$USES TX_STR}
This informes the sxb compiler TX_STR is to be used so it reserves an entry for it.
You then enclose the sub declarations like this:
'{$ifused TX_STR}
TX_STR········· SUB···· 2······················ ' transmit a string
'{$endif}
and enclose the subroutine in xxx_INC.SXB likewise:
'{$ifused TX_STR}
SUB TX_STR
ENDSUB
'{$endif}
This saves jumptable entries.
It still is not ideal, but with a single pass compiler probably the best way.
regards peter
"Best" is in the eye of the beholder -- or programmer, as the case may be. SX/B doesn't enforce any particular style, and I'm simply sharing what I think works best for me. Perhaps you should post [noparse][[/noparse]full] demos so that others can learn from how you've succeeded with SX/B.
Attached are your files but modified as per my suggestion.
Note that I added a '{$define libname} to each library DEF file.
That define is then used to load the INC later on.
Big advantage here is when a specific DEF is·no longer·loaded,
its companied INC is automatically skipped.
Also note that I listed all requirements·for the libraries in the DEFs,
like STACK needed, but for TX_SERIAL also the BaudMode constant
which must be defined externally.
Adding the '{$uses subname} really·is no big deal.
When there are a lot·of library subroutines used, you do get
a long vertical list of·$uses.
I·have requested in the past, and I still request it, is to have $uses accept
a comma seperated list.
My suggestion is:
'{$uses libname: sub1name, sub2name, ...}
where libname can be any text, it acts as comment ended by : but using the library name
seems most appropiate.
In the attached demo it·then would look like
'{$uses pvDELAYS: DELAY_MS}
'{$uses pvTX_SERIAL: TX_STR,TX_BIN,TX_HEX}
Consider not using $uses and·the subroutine jumptable does get filled with unused subroutine entries
so your program does not compile (too many subs).
Then you will need·to copy and rename libraries and removing unrequired subroutines.
regards peter
