How to glue down an SD card breakout board?
Hey all,
I've got an SD card breakout board from SparkFun, and I'd like to secure it to the inside of a metal enclosure. Except for some exposed pins that I need to keep away from the enclosure, the bottom of the breakout board is smooth, flat PC board material. I was wondering how to glue this down. Would plain epoxy work okay? Superglue? Chewing gum maybe?
Comments and suggestions greatly appreciated.
thanks,
Mark
www.sparkfun.com/commerce/product_info.php?products_id=204
thanks,
Mark
http://www.thistothat.com/
It's non-conductive, holds well on everything except metal, and holds halfway decent on metal.
It can be scraped off fairly easily with an xacto knife and its completely non-toxic.
I love the stuff... As you can most likely tell by all the pics of my robot.
Mike,
is this the same silicone rubber people use for fixing gaps in windows and doors, like what they sell at Home Depot? or something fancier?
thanks,
Mark
I'm with Mike - I use a 5 minutes 2-part epoxy for stuff that doesn't need to come unstuck.
My second choice is silcone sealant - which really does stick to evrything rather well. I use "Selleys Wet Area Silicone Sealant", the most important thing is to get a sealant that's marked as non-corrosive; this is VERY important as the corrosive ones will eat electronics and plastics. The corrosive one has the vinegar smell. The other option is an electornics-grade two-part silicone but that costs about 10 times more than the Selleys.
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
If only Sparkfun had a put a couple of flanges or something to screw onto, then mounting this sucker wouldn't be so annoying. (That's a hint to all you board developing types out there: for me, getting things mounted and connected seems to take 2x as much time as wiring the circuits - ugg.)
cheers,
Mark
