what gets loaded to a cog
I'm not sure how I haven't run across this before, but I'm trying to figure out the logic.
I have a program:
The question is, what is being loaded to the cog. I assume the rfid method is there, but what about the methods that rfid calls: ReadRFID, CheckRFID, and pause? Seems like a bit of a waste if the called methods aren't put onto the cog. But then how that work with calling methods of a another object (is the whole object stored or just the method).
Anyway, I'm sure someone just has a simple answer for this.
I have a program:
CON
RFID_SERIAL_p = 14 ' RFID serial data
RFID_ENABLE_p = 4 ' RFID /ENABLE pin
VAR
BYTE cogon, cog
LONG rfidstack[noparse][[/noparse]50], RFIDdata[noparse][[/noparse]12]
PUB start_rfid (door_outputAddr)
stop
cogon := (cog := cognew(rfid(door_outputAddr), @rfidstack)) > 0
PUB stop
if cogon~
cogstop(cog)
PUB rfid (door_outputAddr) | i
REPEAT ' repeat forever
ReadRFID ' get RFID value
IF (CheckRFID)
byte[noparse][[/noparse]door_outputAddr] &= %011 ' force bit 2 to 0
pause(1000)
ELSE
byte[noparse][[/noparse]door_outputAddr] |= %100
PRI ReadRFID | bit, time, deltaT, i
DIRA[noparse][[/noparse]RFID_SERIAL_p]~ ' Set direction of RFID to be an input
DIRA[noparse][[/noparse]RFID_ENABLE_p]~~ ' Set direction of RFID_EN to be an output
deltaT := clkfreq / 2400 ' Set deltaT to 1/2400th of a second for 2400bps "Baud" rate
OUTA[noparse][[/noparse]RFID_ENABLE_p]~ ' Enable the RFID reader
REPEAT i FROM 0 TO 11 ' Fill in the 12 byte arrays with data sent from RFID reader
waitpeq(1 << RFID_SERIAL_p, |< RFID_SERIAL_p, 0) ' Wait for a high-to-low signal on RFID's SOUT pin, which
waitpeq(0 << RFID_SERIAL_p, |< RFID_SERIAL_p, 0) ' signals the start of the transfer of each packet of 10 data bits
time := cnt ' Record the counter value at start of each transmission packet
waitcnt(time += deltaT + deltaT / 2) ' Skip the start bit (always zero) and center on the 2nd bit
REPEAT 8 ' Gather 8 bits for each byte of RFID's data
RFIDdata[noparse][[/noparse] i ] := RFIDdata[noparse][[/noparse] i ] << 1 + INA[noparse][[/noparse]RFID_SERIAL_p] ' Shift RFIDdata bits left and add current bit (state of RFID pin)
waitcnt(time += deltaT) ' Pause for 1/2400th of a second (2400 bits per second)
RFIDdata[noparse][[/noparse] i ] ><= 8 ' Reverse the order of the bits (RFID scanner sends LSB first)
OUTA[noparse][[/noparse]RFID_ENABLE_p]~~ ' Disable the RFID reader
PRI CheckRFID | i
REPEAT i FROM 0 TO 9 ' Compare tag's 10 unique ID #s against ID #s stored in data table
IF RFIDdata[noparse][[/noparse]i + 1] <> tag1[noparse][[/noparse] i ] AND RFIDdata[noparse][[/noparse]i + 1] <> tag2[noparse][[/noparse] i ] ' ...etc.
RETURN 0 ' If one of the IDs does not match, return a zero
RETURN 1 ' If one of the ID sequences matched, return a one
PUB pause (wait) | ClkCycles
ClkCycles := ((clkfreq / 1000 * wait) - 4296) #> 381
waitcnt(ClkCycles + cnt)
DAT
tag1 byte "XXXXXXXXXX"
tag2 byte "XXXXXXXXXX"
http://forums.parallax.com/showthread.php?p=765086
