Is there a user preference on available Rechargeable Battery Chemistry?
Beau Schwabe
I would like to see what kind of rechargeable batteries that you most frequently use, and if there is a preference you have over one or the other.
Since there are many different shapes, sizes, chemistry, capacity, etc. available, be sure to include this information as well if you can.
Thank you.
Beau Schwabe
IC Layout Engineer
Thank you.
Beau Schwabe
IC Layout Engineer
NiMH for AA (Energizer 2200 mAh)·and I am using a SLA (Power Sonic PS 1270 -·7Ah·or 1272 - 7.2 Ah)·for the 12 volt motor and wheel kit bot.
Whit+
Ken
In motor home, flooded lead-acid deep-cycle batteries.
In cameras, NiMH AA.
In flashlights, NiCd.
In laptops, NiMH mostly.
In photoflash units, NiCd and NiMH.
In UPSs, Sealed lead-acid (SLA, all glass-mat at the moment, I think).
In handi-talkies, NiCd.
Lessee -- that about covers it.
· -- Carl, nn5i@arrl.net
John Abshier
The NiMH battery in my weather station has only had one problem this winter. We had a "dark week" where there was cloud cover with rain and snow. The solar charger output was inadequate to recharge the battery and I had to take it out and hook it up to a wall charger. It has functioned well at temperatures down to -2F.
Curious, What brand of battery is that? I am using energizer AAA's and they bug out at about 34F. It's kind of funny to see me standing over my app with a heat gun just to load a program!
For electronic devices, cameras, radios etc., the Eneloop AA cells have been working well, they do hold a charge for extended periods of non use.
Overall, I mostly use NiMH. I have had more cells fail with NiCads than any other cell type.
Rich H
Not saying I wouldn't love to be able to use Li-Ion in projects - it's just that I don't trust them.
I use Ni-MH AA's in my small projects, and Lead acid in my giant robots. I've never been quite sure why you can find AA NiMH that are rated 2500+ mAH, but C size NiMH batteries are rated only 2000 - 3000 mAH. (I've seen them as poor as 1500mAH). You'd think a C battery would have twice the energy of a AA. My suspicion is that because C batteries are less commonly used, the battery companies only make AA and are cheating consumers by making C batteries that are nothing more than AA batteries with a fat plastic shell around them.
The battery pack I am using is listed here:
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=1482
It was designed to use with a bicycle light. They also sell 5000mAh "C" cells and 10000mAh "D" cells.
Didn't mean to hi-jack your thread Beau, sorry!
Back to the topic. I like the 7.2 NiMh RC batteries that Radio shack carries. Not because of their size, but because of their availability, and cheap chargers. Being able to design circuits of my own to charge them with is also a plus!
I usually use 12 volt SLA in the range 1.2 to 7 Ah and have a solar float charger for those built into my data logger. They have good performance even at low temperatures. Sometimes small 6 volt SLAs from 0.5 to 1.2 Ah is fine too, depending on external requirements. For some stations that have to run at very low temperatures from primary batteries, I've used the Energizer L91 Lithium Disulfide AA batteries, or CR123 LIMnO2's. In one project where the enclosure was fit for a standard 9v battery, we started using rechargeable Li-ion 7.2 volt packs from the same source MSDtech just recommended. Unfortunately the Li-ion batteries that have the same form factor as the standard 9v do not have as good an Ah capacity as 9V alkalines (AFAIK).
Tracy Allen
www.emesystems.com
Carry on.
I usually operate from solar power, and rely on low dropout linear circuits to charge my relatively small SLA AGM batteries. I've followed the discussions of MPP (maximum power point) chargers here with interest.
Tracy Allen
www.emesystems.com
SLA in anything that requires·large power capacity.
Lithium Ion scavenged from 9.99 cel phones for low power draw logic level stuff. (Nice that they include a free charger and 5v power supplies [noparse];)[/noparse]·
Lithuim Ion and NiMh in the RC planes
horror stories.
